Technical Ax15 behind a 318 poly solved
Discussion in 'The Hokey Ass Message Board' started by Burkedore, Sep 5, 2016.
  1. Burkedore
    Burkedore
    I am contemplating putting an ax15 out of a 94 Dakota behind the poly in my Dodge d100 and I have hit a bit of a bump in the road. The input shaft is not long enough to make it in the pilot bushing. Is there an off the shelf solution for a pilot bushing? Thanks for the help.
    Bruce Fischer likes this.
  2. gimpyshotrods
    gimpyshotrods
    I personally don't remember seeing an extended pilot bushing for an LA engine in the catalogs, but it might exist.
    Any machinist with a stick of Oilite Bronze can make one, in a jiffy.
  3. gimpyshotrods
    gimpyshotrods
    My question is, what are you planning on using for a clutch setup?
    There is a native setup using the 318(5.2l) and the AX15, in the later model trucks, but it has a hydraulic clutch. If you could get the master cylinder onto your pedal, you could use that.
  4. Burkedore
    Burkedore
    The flywheel, clutch, and pressure plate from the 94 are used as well as the starter. The real mess begins when you start looking for an external slave that has some kind of fitting and bleeder that could be used with the stock master cylinder. I circumvented this problem by making my own slave cylinder from aluminum that uses the cup and seal from the '66 slave cylinder.
    squirrel likes this.
  5. squirrel
    those trucks came with a hydraulic clutch. The bellhousing mounts to the frame crossmember, and it's a rather large bellhousing. If I were trying to do this, I think I'd use the bellhousing that matches the transmission, put a crossmember under the back of the transmission, use the later model 318 flywheel and starter, and connect the hydraulic clutch (not sure how that will work, do they use funky modern fittings on the new one? ) and be done with it. But that's just a guess....I've only worked on the old trucks, not the new ones.
  6. Burkedore
    Burkedore
  7. Burkedore
    Burkedore
    That is essentially the plan, the problem is the input shaft is flush with the end of the bellhousing on the ax15 and the pilot bushing is not reachable when bolted to the engine.
  8. Burkedore
    Burkedore
    It looks like I will turn something up on the lathe tomorrow (I am a machinist) I was just hoping I could find an off the shelf solution (time is at a premium right now). Thanks for the help guys.
  9. gimpyshotrods
    gimpyshotrods
    By how much?
  10. squirrel
    sounds like you can fix it....
    what does the later model pilot bushing look like? like this? does it fix your problem?
    NATIONAL FC69907
  11. gimpyshotrods
    gimpyshotrods
    You sir, have the key, and my envy. I am only really good at running the cutter or end mill into the jaws/clamps.
  12. Burkedore
    Burkedore
    About 3/4"
  13. Burkedore
    Burkedore
    I am going to pick one up on my way to work tomorrow to measure, I wonder how similar the crank flanges are between the poly and 3.9v6?
  14. squirrel
    should be the same, they sort of standardized it by the early 60s. But you never know with old Mopars, they sure screwed with things way more than necessary. Might be that the crank has the small pilot. I seem to recall they changed the size of the pilot hole that the automatics used, some time in the early 60s, and that messes up engine/transmission swaps.
    If you want better help when you're asking questions like this, it really helps for you to add some photos, because some of us just can't remember what stuff looks like, that we worked on 30+ years ago.
  15. Burkedore
    Burkedore
    I don't know seems like you are doing fine so far.
  16. squirrel
    I know there was something different with some of the crank flanges, but I don't remember what. I think the early torque converters used a pilot that was deeper and smaller ID than the later ones. I know we tried to stick an early engine in a later car, and decided to get a later engine, because there was no way to make it work...this was on an engine swap I worked on in the mid 80s.
    Anyways, hopefully that bearing will fit your crank, and solve the problem. If not, you can make a new sleeve from aluminum (?) that will fit your crank flange.
  17. Bert Kollar
    Bert Kollar
    I'm not a machinist but I made two of them for friends and they work fine
  18. squirrel
    When I'm standing in front of my old lathe, I'm a machinist :)
    Hnstray likes this.
  19. gimpyshotrods
    gimpyshotrods
    When I'm standing in front of my old lathe, I'm trespassing.
    Burkedore and Hnstray like this.
  20. Burkedore
    Burkedore
    Well I picked up a pilot bearing for a 94 Dakota (donar vehicle) the o.d. measures 1.815". The I.d. of the crank flange is 1.775", close but that would be one hell of a press fit.
    While I was there I picked up a slave cylinder to compare to the one I made. I liked it better so I threaded the end for 1/4 pipe and used an adapter to inverted flare.
    Hnstray likes this.
  21. jack_pine
    jack_pine
    from Motor City
    You need to get with Gary Stauffer (73rr here), or at least his website http://qualityengineeredcomponents.com. he has the early hemi/poly to AX15 fully mapped out. Also, Paul Unterstein @American Powertrain has the right clutch, plate. My AX15 behind 392 hemi took one of Gary adapter kits and a 3.7L flywheel redrilled for early crank flange
  22. 73RR
    73RR
    Jon, thanks for the nod!
    I'll assume that the OP has his package sorta out by now....but I'm real curious about his pile-o-parts.
    All of the post-62 A engine, LA engine, and the new 3.7, 4.7, 5.2 and 5.9 all have the same bits and pieces for that he is working with. Something very odd that his input shaft would be short.
    Perhaps he'll let us know how it all worked out.
  23. Burkedore
    Burkedore
    What blanks can I fill in?
  24. Rusty O'Toole
    Rusty O'Toole
    Chrysler makes a pilot bearing for special cases like yours. It is a ball bearing in a cage that bolts onto the flywheel bolts. Dodge dealers should be able to get one. I think it was made for adapting manual trans to an engine made for auto trans that did not have the crankshaft machined for the bearing.
