Projects AWB Chevy II build
Discussion in 'The Hokey Ass Message Board' started by Doctorterry, Apr 10, 2017.
  1. Doctorterry
    Doctorterry
    Rear tires held weight for the first time. Hopefully I can get the front done Monday or Tuesday night since I'm gonna be in Amarillo for the drags this weekend. after stepping back last night and looking at it, I got excited all over again. I forgot to take some pictures of it, but I'll have my dad send me some so I can post them!
  2. Doctorterry
    Doctorterry
  3. Doctorterry
    Doctorterry
    Seems like most of the people that were on my thread earlier on have flaked... probably tired of watching me do things the way I have haha.. anyways, got the slicks mounted and balanced. Looks good
    AHotRod, malibumonte78, enloe and 2 others like this.
  4. DDDenny
    Still here.
    Just keep plugging away and singing that Frank Sinatra song " My way".
    Doctorterry likes this.
  5. Doctorterry
    Doctorterry
    Haha right on. Thanks for the support
  6. Doctorterry
    Doctorterry
    Well, in a hectic attempt to get the shop cleaned up for my dad's '57 coming home tomorrow, this happened... IMG_3028.JPG IMG_3027.JPG IMG_3024.JPG
  7. saltflats
    saltflats
    from Missouri
    So you got evicted? :D
    loudbang, enloe and Doctorterry like this.
  8. squirrel
    it's a roller!
  9. Doctorterry
    Doctorterry
    Well... pretty much
    loudbang, enloe and saltflats like this.
  10. Doctorterry
    Doctorterry
    I told dad I could weld those clamps holding my crossmember in permanently.. then it would be a rat rod and everyone one like it lol
    loudbang and enloe like this.
  11. Doctorterry
    Doctorterry
  12. 56sedandelivery
    56sedandelivery
    One of the very first drag cars to really impress me, was a 62-64 Chevy II, 2 door sedan, with a 427 and TH-400, running brackets, at what was still then called, Seattle International Raceways. Plain Jane, little Chevy II, with stock style steel wheels (including the 4 bolt front hubs/brakes), hitting the ten second mark; this was in about mid 1969, and I was still a highly impressionable 18 year old kid. It was even the stock, light blue that a lot of them were. If I could only go back to that time.............................................................I am Butch/56sedandelivery.
  13. Doctorterry
    Doctorterry
    Thanks for sharing! I am really leaning towards painting this the stock light blue. I love that color! IMG_2698.JPG
    38 2 DR Sedan, loudbang and enloe like this.
  14. saltflats
    saltflats
    from Missouri
    When I was out of high school, my 62 Nove II was black with red interior. :cool:
    loudbang and Doctorterry like this.
  15. Doctorterry
    Doctorterry
  16. enloe
    enloe
    from east , tn.
    JUST A FEW LITTLE TWEAKS THEN GOOD TO GO :)
    Doctorterry and loudbang like this.
  17. Doctorterry
    Doctorterry
    I’m about to start my last semester of school, and I’ve been working more, so I’ve stayed busy. I got the front wheels on though, and they look great. [​IMG]
    AHotRod, Fiddle Picker, TFoch and 3 others like this.
  18. wrenchbender
    wrenchbender
    One step at a time man you will get there and one day you might be able to line that pile up next to my pile at the strip lol
  19. Doctorterry
    Doctorterry
    Im looking forward to it!!
  20. Doctorterry
    Doctorterry
    I went ahead and ditched the small bearing rear end. I picked up a big bearing rear the other day and tore it apart. I’m going to narrow the housing to 50”. Grandpa surprised me with a new spool and he’s giving me his old 4.88 gear set up!
  21. wrenchbender
    wrenchbender
    Doctorterry, loudbang and enloe like this.
  22. DDDenny
    Please tell us how YOU plan on narrowing it.
    If you are having it done professionally.......your golden!
  23. Doctorterry
    Doctorterry
  24. Doctorterry
    Doctorterry
    I’m going to have it done
  25. Doctorterry
    Doctorterry
    Do you ever think, what was I trying to do when I did that? So tonight I hit the reset button and welded the ends of the crossmember back on, and then cut them back off a lot better. It now is a snug fit down into the frame rails, and I have the hang over on top of the frame rails. I plan is to heat them up and bend them over the frame rail and then weld it in
  26. Doctorterry
    Doctorterry
    I got my steering box mounted, had some steering linkage that will work for temporary steering, and I extended my steering shaft 10” which put the steering wheel about 5” further back than stock. I got the crossmember tacked in too. It’s a pretty cool feeling to turn the wheels with the steering wheel for the first time!
    [​IMG][​IMG]
    enloe and loudbang like this.
  27. Doctorterry
    Doctorterry
    Is sleeving the bolt holes through the frame for the steering box a common thing to do, or is it not necessary?
  28. squirrel
    It is necessary, unless you make a bracket. You can't just drill a hole through both sides of a frame tube, and stick a bolt through it, and expect it to hold a steering box in place. The tube will crush, you won't be able to fully torque the bolts.
    enloe, loudbang and Doctorterry like this.
  29. Doctorterry
    Doctorterry
    That’s what I assumed would happen. Thank you
  30. looking good .... its coming out as an interesting build
