AV8 steering column issue
Discussion in 'The Hokey Ass Message Board' started by hydroshawn, Jul 13, 2013.
  1. hydroshawn
    hydroshawn
    from Brenham,Tx
    I've tried looking thru some threads but really didn't find much on this issue.
    I installed a 1951 Merc motor with a 1939 tranny.
    the issue is the left rear corner of the motor is touching the stock 1929 column housing.
    any one come across this issue & how did you fix it?
    Thanks in advance!
  2. Rickybop
    Rickybop
    from Michigan
  3. or to far rearward. can you get the passenger head off?
  4. Russco
    Russco
    from Central IL
    Mine was like that, it just interfered with the outer mast housing. I notched the housing for clearance I think I also shimmed the motor up a touch too.
  5. woodypecker
    woodypecker
    The model a has teo different column drops. One is attached to the tank the other is attached to the cowl. It is easier to move the one attached to the cowl around. The one attached to the cowl also is safer it does not fatique a crack in the tank.
  6. Rickybop
    Rickybop
    from Michigan
    He's got his column hanging well below the drop, and it's still touching the head.
  7. hydroshawn
    hydroshawn
    from Brenham,Tx
    WOW!! great info guys! I got rained out at work today so I've been scouring on pictures.
    I did find that most people are using F1 boxes & removing 1 to 1-1/2 inches between the housing & the bolt plate.I didn't want the column to be too far off on any angle side to side
  8. hydroshawn
    hydroshawn
    from Brenham,Tx
    So I could cut the one on the tank (or leave it) and go with the something different & notch the steering column housing as well?
  9. hydroshawn
    hydroshawn
    from Brenham,Tx
    what with and how much did you shim?
  10. hydroshawn
    hydroshawn
    from Brenham,Tx
    It is possible that it might be too low. my mounts are welded under the frame lip. I'm using an F1 center crossmember for my 39 tranny to the model-a rear.
  11. hotrodderhaag
    hotrodderhaag
    Lots of pics in the build thread that is in my sig. Switch it to an f1 box. I tried to use the stock box in my build and it was a disaster. F1 box is fairly cheap. And it makes the car handle soooo much better. Don't waste your time , just switch it
