AV8 Question
Discussion in 'The Hokey Ass Message Board' started by Ghost of ElMirage, Apr 24, 2012.
  1. Ghost of ElMirage
    Ghost of ElMirage
    :confused:When installing a 59A flathead in a 28/29 Ford roadster or RPU will the stock fan and generator assembly clear the radiator or will I need to modify it or fab something new all together?
    thanks everyone
    Ghost[​IMG] <!-- / message --><!-- sig -->
    __________________
  2. it will not fit. Use a single belt pulley and a early generator with the fan mounted on it.
  3. Ghost of ElMirage
    Ghost of ElMirage
    Ok Hitch so what year flattie fan and generator am I looking to buy parts off of?
  4. There are sources that sell a pulley to adapt a fan to your generator.Some pulleys are wide or narrow belt.Speedway my have something.
  5. Ghost of ElMirage
    Ghost of ElMirage
    Thanks but I want to use as many original Ford pieces as possible
  6. Ghost of ElMirage
    Ghost of ElMirage
  7. I used a 39 generator and fan, I had a guy turn the outer/forward pulley ring off the lower. Nothing else involved aside from a little trim on the fan blades. You DO NOT need to trim the firewall or move the rad.
      143.7 KB
  8. Again...
  9. Ghost of ElMirage
    Ghost of ElMirage
    Thanx wide! That helps ALOT man.By the way why did you keep the exhaust crossove pipe?
  10. stainlesssteelrat
    stainlesssteelrat
    from ms
    aye.. what ^ they said.
