I have a 12v coil and requires an external resistor. I am ok with having the external resistor. What ohm value should i get? I have a reworked chevy distributor in a flathead. Thank you
It is a 12v chevy I got at the local auto parts store. The package said to use with external resistor.
Standard ignition products RU10 works for the late 50"s-early 60"s 12v Chevy ignition.I run one on my Chevy small block with points.
