Technical Automotive parts in industrial applications
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Mar 27, 2021.
  1. lewk
    lewk
    from Mt
    Old Federal logging contraption with an Olds powered crane:
    01722660-6970-4B4C-98C4-221A0DFB8DCB.jpeg 56044D56-E38E-4ABE-ACD2-66F6DF41A77D.jpeg 3E749ECE-69A8-4A92-B3CE-74A58C424377.jpeg 01569AF9-8B5A-44ED-8A4F-02141B87C98A.jpeg
  2. Fortunateson
    Fortunateson
    The spelling on that sign would be enough to scare me off! Any banjo music?
    Caprice89 and lewk like this.
  3. Sandgroper
    Sandgroper
    Found a grey motor the other day in of all things a Qantas tug (pulls baggage carts and planes around) at Perth Airport. Still running well.
    Dad put one in an old grey Ferguson tractor to replace the Vauxhall petrol motor it came from the factory with.
    Used to see a lot of grey motors driving the back of cement mixers years ago.
    Harvs (from Perth)
  4. Sandgroper
    Sandgroper
    Lol I reckon I'd hear that from WA.
  5. cfmvw
    cfmvw
    Worked at a place that had a big block Chevy converted to propane that ran a backup generator. We used to service it every now and again, but I don't think it was ever used during my time there.
  6. GTS225
    GTS225
    Not too much industrial, but a lot of agricultural, and almost out of era for this board.
    The slant 6 Mopar was used in Hagie hi-wheel sprayers, some combines, and a handful of fruit and nut tree shakers. I have also witnessed a factory install in an airport tug, and a White-branded forklift. Also used in some boats back in the day, and have heard of them being used in irrigation pumps and ground power units, but have never seen any evidence of such. (Oops, almost forgot the Cortez motor home that was built with a slant and unique front wheel drive manual trans.)
    Roger
  7. jimmy six
    jimmy six
    When I worked in the oil fields from 62-67 almost all the vacuum trucks used Chevrolet 6’s for vacuum pumps. They were run off the pto and had a way different head on them.
  8. rusty valley
    rusty valley
    I had a model A powered airport tug years ago, sold it to a guy in chicago that had a whole collection of that sort of stuff
    VANDENPLAS likes this.
  9. rusty valley
    rusty valley
    AND, in my youth, the kiddy train at the excelsior amusement park was model A powered too
  10. moparboy440
    moparboy440
    from Finland
    An old Ginge 6x6 FireTruck sitting and rotting away. 413 Chrysler powered waterpump and Rolls Royce straight 8 petrol drive engine!
  11. mickeyc
    mickeyc
    I have a 331 Chrysler industrial short bell motor that was used
    at the New Orleans airport to power planes sitting on the tarmac.
    It has a unique oil system that controls the engine speed governor.
    Totally mechanical with no electrics involved and adjusted by
    1/4 inch oil lines and thumb wheel valves. The genset has been
    adapted to 6 cylinder diesel and has powered several neighborhood homes and
    businesses during one of our frequent power outages. After it sat
    for several years I bought it, oiled up the cylinders cleaned up the
    points and plugs changed the carb and fired that thing up sitting
    on its original cradle, less the the gen. I still have it sitting in my
    shop.
    fauj likes this.
  12. 41woodie
    41woodie
    During Vietnam the Marines had an anti-tank vehicle called an ONTOS. Supposedly they had 413 mopars in them. If the 413 isn't impressive enough they also had six 106mm recoilless rifles mounted on them
    Lepus, Torkwrench, fauj and 2 others like this.
  13. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    The Ford 300 inline six has some impressive industrial credentials. Among them:
    AIRPORT TUGS
    WOOD CHIPPERS
    BOATS
    MARINE LIFTS
    SIDEWALK SNOW PLOWS
    SNOW CRAWLERS
    STATIONARY GENERATORS
    WELDERS
    IRRIGATION PUMPS
    AIRCRAFT
    COMBINE HARVESTER
    IRRIGATION PUMPS
    BOATS
    RAIL CAR MOVERS
    CRANES
    BOAT HOISTS
    HARROWS
    CHERRY HARVESTERS
    SEWER CLEANER PUMPS
    LOG SKIDDERS
    RAIL SPEEDERS
    DIRT PACKERS
    Here's a couple I've seen - a tracked snow plow and a CONCRETE PUMP:
  14. woodbutcher
    woodbutcher
    :D Where I grew up in Florida,the local flood control distric`s main pump house had six 6-71 Jimmy Diesels hooked to 6 48" ID screw type pumps.Talk about moving some water in a hurry.Those would do it.
    Good luck.Have fun.Be safe.
    Leo
    VANDENPLAS and rusty valley like this.
  15. 1971BB427
    1971BB427
    from Oregon
    It went the other way also! There were industrial use engines with larger displacement that found their way into hotrods also! Back when Mopar had their flathead 6 banger, the industrial version was a bigger 244 c.i. engine. Old hotrodders soon found out the bigger engines fit right in their Plymouth and Doge cars, and began buying them up.
  16. 57tailgater
    57tailgater
    from Georgia
    One rigging and machinery moving company I worked for had a couple of 30,000# fork trucks. They both had International 345 gas V8's in them.
  17. Budget36
    Budget36
    I’ve an old forklift that from my understanding, was common to make them from the airport tugs Mine had a 218 Dodge engine.
    My old big Henry lathe came out of a industrial shop somewhere, it has the 3 drums on it to change speeds via a flat belt. It is fitted with a 1725 rpm motor that was apparently to fast , so whoever had this after shop use fitted a 3 speed transmission on it to gear it down. Crude, but effective!
  18. Budget36
    Budget36
    Also, my neighbor has many Hemi engines and parts he’s collected from air compressors, generators, etc. He won’t sell/ trade a darn thing.
  19. lowrd
    lowrd
    During the summers off from school, I would visit my grandparents near Port Townsend, Wa.
    I recall seeing a model B engine and trans hooked to a large reel of cable all mounted on a platform of logs lashed together. They were used to bring logs across rough terrain to the landing for loading on trucks. Gramps told me these units were called "donkeys" and replaced the steam powered units which were very unsafe and prone to blowing up. I only watched the donkey being used once in the early 60's. It was one hell of a wild ride for the operator when the logs would become jammed.
  20. Harv
    Harv
    from Sydney
    Was the Qantas tug still in service at the airport? That would be impressive.
    Qantas strikes me as fairly up to date with their kit, but it would be pretty cool if they were still running a grey. I have a mental picture of an old, grizzled ground support fitter carefully maintaining the 70-year old grey motor.
    Cheers,
    Harv
  21. Truckedup
    Truckedup
    Around 1990 I bought a Ford flathead V8 powered snow blower for the engine...The engine was badly cracked and unusable...
  22. Mr48chev
    This old wood frame wind machine sat in front of a local wind machine manufacture for years until they changed hands. Many of the wind machines around here have big block engines running on propane driving a rather complicated drive system to work the 12 ft prop now or have a big electric motor to run it.
  23. Sandgroper
    Sandgroper
    Yep still in service :) also found an older red motor in a Menzies aviation tug.
  24. spanners
    spanners
    I can vision a young fella looking at it and shakeing his head because he wouldn't know what it was let alone how to maintain it.
  25. 51504bat
    51504bat
    Back in the day most of the wind machines in Inland SoCal had flatheads. Some were electric but from what I remember most were flatheads. Still some in active service but not near as many as when orange was king. A buddy got a 59ab with a 4 speed truck trans out of a wind machine. The trans was locked in 4th gear and then coupled to the propeller assembly. He put the motor in his '30 Model A. Used the same clutch since it was like brand new. I got the trans for a '40 1 1/2 ton flat bed I had. Trans was in perfect shape.
    jimmy six likes this.
  26. big bird
    big bird
    Company I worked for in the 80s had a tow-behind compressor/generator that had a flathead 8. One bank was set up to be the compressor, the other side was the engine. generator head ran off the back where a trans would go.
    Flathead 4-bangers were common in forklifts and such at one time (usually running on propane)
  27. Harv
    Harv
    from Sydney
    Damn that's cool. Perth is not a huge airport, but big enough that I would not have guessed that it still had greys and reds in the fleet.
    Lol. Wonder if they are running it into the ground, or maintaining as per factory. An airside tug doesn't do many miles, but over 70 years there would be a fair few oil changes, dizzy greasing, points changing etc.
    Cheers,
    Harv
    Sandgroper likes this.
  28. spanners
    spanners
    That Grey motor in my avatar originally came from a timber mill saw bench powering a 6 foot blade. When I dissasembled it there was little wear in the bores because it would be switched on in the morning, run all day under load and switched off in the arvo and allowed to cool gradually.
  29. I worked at an airport (for TAA) and drove a heap of tugs, mobile stairs, mobile conveyors, fork lifts, etc.
    The small aircraft tug we had was powered by a Dodge flathead 6, with a pre-select auto box. When the young new ground equipment mechanic was hired, he did just that- scratched his head and said "What the hell is this motor?"
    I used to drive a Chrysler Royal in those days, so I would lend him my manual and he would photocopy all the engine sections he needed. The baggage tugs were powered by Ford 177 or 200 CI 6's, with a BW35 trans and engine speed governor (Which we would disconnect and have drag races on night shift), same with the mobile stairs and conveyors.
    Forklift had a Holden red 202. The local Christmas Pageant here uses a fleet of small tugs, most powered by '50's and '60's British side and OHV 4 cylinders.
  30. 1952henry
    1952henry
    Slant sixes were used in John Deere swathers in the 70s. 292 Chevies were used in MF 410 combines, as well as John Deere 4400 combines. 4 bolt 327s were used in early MF 510 combines, replaced by 350s in later 510s.
    Chrysler flathead sixes (251, I believe), Dodge truck 5 speeds and rearends were used in Coop #3 tractors.
    Massey Harris 101 tractors used 201 and later 217 Chrysler sixes
    Truckdoctor Andy likes this.
