Customs Autometer gas gauge
Discussion in 'The Hokey Ass Message Board' started by mack57, May 10, 2015.
  1. mack57
    mack57
    Hi All,
    Just wired a new autometer gas gauge. It seemed straight forward but, reads only full,(The tank is nearly empty).
    It is a new 0-30 ohm sender & the gauge is also 0-30ohms.
    Any thoughts on what I may have done?
    Thanks,
    Mack
  2. 325w
    325w
    Grounded circuit. At the tank check to see that the terminal is not touching the sending unit. Pull the sending unit nut. Make sure it's not touching metal. Turn on the key. Should not move then. I hope maybe?
  3. 40FORDPU
    40FORDPU
    from Yelm, Wa
    1. Northwest HAMBers
    I just went through this with my Autometer fuel gage, it was the ground at sending unit.
  4. mack57
    mack57
    Thanks Guys,
    I'll let you know!
  5. mack57
    mack57
    325w & 40FORDPU,
    Grounded the sending unit & it is working!! Thank You Guys!!
