Technical Auto body saw
Discussion in 'The Hokey Ass Message Board' started by Sporty45, Apr 26, 2018.
  1. Sporty45
    Sporty45
    from NH Boonies
  2. oldolds
    oldolds
    I never really liked any of them. Used a couple different ones. Like using a saws-all. They can be jumpy. You always wear the same part of the blade out quickly on sheet metal. As soon as the blade hits that hidden bit of structure it is bent and useless.
    Your results may vary.
    Hnstray, j-jock, texasred and 2 others like this.
  3. They are a bit jumpy
    But I use mine a lot
    It’s small and fits in places a die grinder with a disc can’t etc etc
    Takes some getting used to as it bites and grabs sometimes
    Over all a good tool
    Sporty45 likes this.
  4. papajohn
    papajohn
    I bought a cheap electric one at harbor freight. Works pretty slick.
  5. I bought a no name brand and the blades would rattle loose. Took that one back and bought an Ingersoll Rand. Don`t buy cheap blades, keep the base in contact with the metal and you should be good to go .
  6. Stooge
    Stooge
    I have an Ingersoll Rand 429, works pretty well for not being a high end one, but I don't know if I would venture to go to a cheaper one as even at its $80 price point, it can be a little fussy sometimes. I usually just buy a pack of lenox hacksaw blades and clip them into 1/3rds and use those instead of the specific body saw blades as they are usually expensive and the narrow ends make them a little flimsy. https://www.amazon.com/Ingersoll-Rand-429-Heavy-Reciprocating/dp/B00004XOT3
  7. Atwater Mike
    Atwater Mike
    My bud did, too. At $17.00, (!) I followed suit. We don't use them much, but they are handy when needed.
    Cheap blades do wear out in one place: the 1/2" or so of contact area. Good blades are 50% better in longevity. I recommend it. $17 for this much 'extra'?
  8. Dave Mc
    Dave Mc
    They work ok , but to save the blades from wearing out fast or breaking , I use Bees Wax or Candle Wax over the Scribe Line to Lubricate the Blade , Helps a lot .
  9. Sporty45
    Sporty45
    from NH Boonies
    Good idea, I never would have thought of that :cool:
  10. zzford
    zzford
    I prefer an air hatchet.
    325w, Hnstray and kidcampbell71 like this.
  11. Atwater Mike
    Atwater Mike
    Wow...Like to see that in use...the name denotes anticipicatory action, I can tell you.
    zzford likes this.
  12. mikhett
    mikhett
    from jackson nj
    I use an electric cutoff wheel on a 4.5 angle grinder.Saves the air compressor! I have a Astro pneumatic air saw.
  13. EW_
    EW_
    from DFW
    I have a Matco MT2215 and I love it. I saw one in use on a TV show where the operator was using it one handed over head cutting out a wheel well like butter. Having used cheap-o air saws in the past, I was surprised at how well it cut. Not inexpensive but I don't mind paying for good tools.
  14. ABONES
    ABONES
    I started with a IR. Used for many years. Bought a high priced Snap on gear driven air saw. Worth every penny . Cuts extremely smooth and doesn't jump .I never buy Snap on stuff, but this was definitely worth it.
  15. cretin
    cretin
    I have a snap on one. Kind of expensive, but it works great, I love it! I use it all the time.
    Also, as for good blades, I use the brand “Bahco” they make the snap on brand blades, but are cheaper if you just get their brand.
    Sporty45 and ABONES like this.
  16. cretin
    cretin
    Also, I should point out, in my experience, it’s worth it to get a quality body saw. All the cheap ones I’ve used haven’t worked very well, so I avoided the saw.
    Then I tried someone’s snap on saw, and I was an immediate believer. I bought mine and use it constantly.
    Just one mans experience.
  17. Sporty45
    Sporty45
    from NH Boonies
    Hmmm... might have to save up a bit if I want a good one, I guess. Thanks everyone ;)
  18. Budget36
    Budget36
    Make sure you get one with and adjustable fence...let's you work on a different part of the blade. I do as mentioned before, just snap off a hacksaw blade and don't buy the higher priced ones.
    I run mine at just enough air pressure to keep the cut going, after you've toasted a few blades, you'll see why;)
  19. Stooge
    Stooge
    Ive been waiting for my ingersoll to break to buy the snap on one. Beng able to use 6" reciprocating saw blades in it alomg with the standard sized body saw blades could really come in hady!
  20. indyjps
    indyjps
    Mine looks the same as the eastwood, but is another brand with grey case instead of blue. Theyre good to have, but are finnicky. Use where the angle grinder won't reach.
  21. rnscustom
    rnscustom
    Ingersol here , as said buy the hacksaw blades and cut them ,
    reagen and Sporty45 like this.
  22. gimpyshotrods
    gimpyshotrods
    I have an Ingersol Rand one, too. I use it constantly, without complaint.
  23. I have an Ingersol air powered saw, but prefer the sawzall, both battery and plug in power, for larger jobs. I also use an air nibbler for tight areas, and have a Mikita electric shear for cutting flat material.
    For some jobs, it is necessary to use a thin cutoff wheel, but I don't like the amount of cutting dust that gets spread everywhere.
    Bob
    bct and Sporty45 like this.
  24. DAHEMIKOTA
    DAHEMIKOTA
    from Tenn
    I have a Craftsman. I use it to cut every thing from wood to 1/2" steel. Cuts roll bar tubing like it is hot butter.
  25. southcross2631
    southcross2631
    I have a Harbor Freight saw that I have used for 5 years now. Still works when I need it to.
  26. Duke
    Duke
    Just chopped my car with my friends snap on air saw. Works really well, he said his cheaper one was not even close to being the same tool.
    ABONES, Sporty45 and cretin like this.
  27. reagen
    reagen
    i use hack saw blades ,break them into .
  28. ol-nobull
    ol-nobull
    Dang, last night I watched a movie on Dish called IQ where the local (wherever that was) rod shop/gas station cut the roof off of Albert Einstein's old 2 door and made it into a convertible. All they used was a skill saw for the job. Maybe it worked was because they were working around genius. LOL Jimmie
  29. stanlow69
    stanlow69
    from red oak
    I used mine to cut speaker holes in package trays. You can`t get any other kind of saw in that tight area. It worked 3 times then broke, Harbor Freight. I didn`t know if I would use it much, so that`s why I bought a cheap one. $19.
  30. Hack saws have cut many roofs off of cars..
