Aussie 1930 Roadster Build
Discussion in 'The Hokey Ass Message Board' started by Turns, Apr 13, 2012.
  1. gnichols
    gnichols
    from Tampa, FL
    Super nice job on that pan. Gary
  2. Wardog
    Wardog
    Awesome work. You've got to be happy with that. If that was you're louver press frame in the background, it's looking good too.
    Sent from my DROID device using the TJJ mobile app
  3. Turns
    Turns
    Yep that's it. It has progressed since then but still needs to be finished. I plan to use a pneumatic ram to actuate the press. I will do 2", 3" and 4" louvers and may do more than one 'style' to see what I like - i wll post the results when I am done:confused:
  4. Just went through the whole thread. Very impressive work! Looking forward to seeing the progress.
  5. brady1929
    brady1929
  6. Turns
    Turns
    Yep, that's the start of the louver press in the background
    I had to do a bit of work to finish off the quarters to tighten them up
    And then took the big step (for me) of folding and shrinking the quarters at the door edge. At this stage I was worried about the bead lines lining up properly to look right.
    I am looking forward to getting into some work over the Christmas break
    Cheers Turns
  7. a bloke
    a bloke
    Awesome - you should be very proud of your efforts.
  8. wandi harry
    wandi harry
    Turns, yep you should be proud. Huge amount of work going into it.
    When do you sleep? Really dig the pan.
    What type of stripper did you use? Looks to be very effective
  9. Turns
    Turns
    Thanks guys - yep lots of work and many hours right there. Sleep?? I will sleep later on :D
    The stripper was garden variety available at a hardware store. I have since been told that after you apply the stripper to the panel, you can cover it with plastic (garbage bag??) and it will work better and more completely in the stubborn areas.
    Food for thought
    Cheers Turns
  10. caddy346
    caddy346
    Your makin it look to easy! Looks good! Just found the thred dont no if it makes it eaiser or harder to get back into my roadster need some of your energy!:D
  11. rcnut223
    rcnut223
    from wisconsin
    Great Job! Your attention to detail is amazing!
  12. Hmmm... I've seen another bloke use this funny looking contraption. :)
  13. Turns
    Turns
    Hey Brootal - the bullseye pick is not so easy to use.....although both of the guys in the pictures seem to have it sussed :rolleyes:
    I haven't done an update on here for ages :confused:
    I bought some tail lights off US ebay and the seller was happy to send them to Australia after an email. I have always liked these Hudson tail lights and have never been in the right place at the right time. These are unpitted and in great condition - the only flaw would be the gaskets are perished which is not too important to me :)....very happy with them
    I am going to refabricate the tail light panel so i thought I would mock them up in the car....I have since moved them outwards slightly :rolleyes:
    The mounting flange is slightly assymetrical to suit the Hudson but i will mess with this later - I have considered linishing them flat but may actually french them into the panel.....we'll see
    I pushed on with a bit more steel out work but nothing major - I still have to complete the steel out with lots of things to consider ie seat belt mounts, seat mounts, etc
  14. Turns
    Turns
    I chilled out on the roadster build and focussed my efforts towards my louver press (I need it to finish my floors :)). There was some interest showed earlier in the thread so I will include the build of it in here.
    I will try to continue on from where I finished off last time. I ordered a piece of 1800mm x 900mm x 5mm steel plate to sheet the press frame. This will stiffen it alot....another scenario where stiffness counts.
    I ordered this steel through my work, source it cheap and my boss wouldn't let me pay for it.....even better ;)
    I cut out the 5mm plate with 1mm cut off discs - no plasma or guillo here:mad: I viewed many aspects of this as practice working heavier gauge steel for when I tackle my chassis build :D
    I left this little tab to help mount the pneumatic ram unit
  15. Turns
    Turns
    I needed to fabricate something to control and adjust the 'shut height' of the ram....this what I came up with
    Did a gusset to support it
  16. Turns
    Turns
    I started fabricating the lower tool mount. Started with two 12mm plates
    Important that these bolts didn't foul on the bottom plate. the Bottom plate will be welded to the press frame and the top plate needs to be adjustable for blade clearance.....hope that makes sense
    This picture shows how the bottom tooling is adjusted. The two outer bolts are tapped into the vertical plates and the two inner bolts are tapped into the tool holder.......in effect, they actually work against each other as jacking bolts. This will allow me to finely adjust the clearance between the top and bottom tooling before fully tightening the bottom tooling into position.
    The clearance is usually set as a percentage of the BMT of the job and is critical to press tooling performance.
    These are some quick designs for louver tooling that I need to do for my toolmaker. Hamish (my toolmaker) needs the louver tooling designs drawn to scale where he can then transfer them to CAD for manufacture.
  17. Turns
    Turns
    I had a heap of large off cuts of 5mm plate from sheeting the press frame. I wanted to use them up and as I have said, practice some metal work :eek:
    I drew this in the car whilst stuck in traffic - kind of wanted an art deco flavour
    Bear with me as this will make sense as I go - I hope
    These are through bolt mounts for the top bracket
  18. Turns
    Turns
    I laid some 5mm plate along the top of the press frame
    Drilled some holes to use as fastening
    Tapped
    Bolted
    Did some crush tubes (all I had on hand was SHS)
    This is the shape I was after. I think there were 30 holes in total to cut in 5mm plate :eek:
    I starting plating the top and the holes are for access to the mounting bolts
    I use this to get at them
    I have used this 50mm hadrail for allsorts of stuff.....mainly metal shaping
    Hacked a bit off
    Cut some short tubes
  19. Pat Pryor
    Pat Pryor
    great job. car looks great!
  20. Turns
    Turns
    I gave the press frame a lick of paint that I use on all machinery at work - charcoal hammertone (hides the grime)
    Started on a table
    I used form ply for the table as it is strong and readily available
    Air pressure regulator and oiler - salvaged off another retired machine :D
    I fitted some switch gear that I also salvaged off another machine (you can see the trend here). I have a good mate that will wire this all up :p
    Hopefully all this is making some sense - I am way behind with my updates :eek:
    Cheers Turns
  21. Turns
    Turns
    Thanks Pat - I know, that you know, how hard it is to fabricate a car from scratch :)
    Cheers Turns
  22. 4444Design
    4444Design
    awesome fab-work with the body and your tools
    everything looks nice 'n tidy - something my workshop never does
    congrats for your outstanding skills
  23. brady1929
    brady1929
  24. Car's great, but that louvre press... WOW! :)
  25. davo461
    davo461
    Amazing project!
    Love the Art Deco look.
  26. dano1930
    dano1930
    wow great job man, thats real deal fabrication right there.
  27. Earlier you said you did not know any hot rodders. With that louver press every hot rodder in the region will be dropping by. Good stuff.
  28. Nekronomicon
    Nekronomicon
    This is insane, love it. Some great ideas
  29. Turns
    Turns
    Thanks for the positive feedback
    Yep, the louver press got a little out of hand :confused:
    A few people are already lining up for louvers - I will do 2X styles in 2'', 3" and 4''
    Cheers Turns
  30. jimbo121
    jimbo121
    Nice work mate, looking really good!
