Very nice turn signal set, two front arrow turn signals (bullet shaped with hoods), two rear and an Arrow brand column mount turn signal indicator. Five piece set, likely NOS with shelf wear, no mounting marks just rub marks probably from box wear. However, one turn indicator is missing the simple mounting base, which may not be needed depending how you mount them. The mounting base is a simple stamped piece that can be swapped to which ever turn light you need it for. Message me if you have questions. $275 including shipping to the lower 48 US states. Ken
