I bought his nice Arrow indícator, at a swapmeet last weekend But i cant figure out how it works? Anyone have an Idea how to conect it?
Thanks I did but could not find one that had the same number and color of the wires. If anyone know the name of it could probably help.
Think a figured it out im not so familiar how US flashers work, there is a Brown Cable from the indikator lamp one side of the light is connected to the Yellow Cable, the other side have the Brown Cable attached.
Did u have the unit itself grounded? Had a similar piece on my old truck. It picked up ground from being attached to the column tube. Sometimes it would lose connection and the blinkers would stop working. If I grabbed the unit and turned it a bit I would get ground back and they would work again. I had no schematic either. I just ran power to mine and grounded it at the column mount, then hooked one wire of a bulb socket to ground. Turn the lever on unit to either left or right indication and start touching wires to the other wire on the bulb socket until you see which wires light the bulb. There will be 2 per side of the car, front and rear. You will probably need a 3 prong flasher can too.
