I picked up these sharp heads the other day, one is perfect the other is missing some fins, looks they were ground off for some reason. Anybody have any ideas on fixing them, who could do it, are they worth spending the money on?
I'm pretty sure they were ground off in order to install stock filter without having to use a riser...why not chrome a stock filter and pop it on there?
I have a set of block letter Sharps like those. My buddy was able to build up the broken fins. They welded very nicely. They were better quality than the Eddie Meyer's that he could not weld successfully. Then I used a die grinder to reshape the weld. You can't tell by looking at them that they were ever damaged. My fins were broken and not ground down as far as those so it was easier to build them back up. It can be done. Build it up higher and wider than what you need and then grind it down to what it once was. The nice thing is that the fins are flat on top which makes it easier to duplicate than a rounded fin.
Yeah, with a stock filter or side mount generator you wouldnt really notice! Just did'nt want them to go to waste!! When I get a chance I'll post some pics of the 2 Edelbrock 2x4 intakes, 2 Offy intakes (a 2x2 and a 2x3) and a set of Weiand heads I got in the same haul!!!
Here is mine. I can't remember which fins were fixed on this side but both sides needed work. He also welded the coolant erosion on the gasket side and I had them surfaced. It only took a few thou to get it flat and smooth.
