April Bang-er thread 2011 OOOGGGAAA BOOOGAAA
Discussion in 'The Hokey Ass Message Board' started by Weeks46, Apr 1, 2011.
  1. Bodger45
    Bodger45
    That a drag, I had similar news earlier this month. Keep us posted on what you end up doing.
  2. Bodger45
    Bodger45
    I recently saw a 'B' block that had a 4''x4'' area in the front of the block that was completely braised over and ground smooth. It was going to be rebuilt. I think a lot of blocks that that would have been considered trash years ago are going to be repaired and used as time goes by.
  3. RussTee
    RussTee
    modern practices are changing there are even sealers that can be uswd in the water chambers of a block to seal minor cracks though I dont know I would want to spend money on a block like that.
  4. saints
    saints
    well tried to start the banger after soaking it and breaking it loose and tuned it up and
    now the fun begins looking through the net for a high compression head and some headers and a 94 carb intake
  5. Bluto
    Bluto
    I have an 'Irontite bench' it is used to pump hot resin into castings to seal them.
    Works to seal castings that weep too.
  6. RussTee
    RussTee
    Bluto that would be a great thing to have I have several veteran engines I would like to do that with just because of their age
  7. Crazydaddyo
    Crazydaddyo
    Congratulations on "waking up" another sleeping banger.
    I'm assuming that the smoke coming out of the exhaust is what is left of what you used to un-stick it.
  8. saints
    saints
    yep the 50/50 mix and it was burning off the block as well....
  9. Bluto
    Bluto
    Found mine for US$200 ..... you start with their cylinder head test bench. In out case I have a 'Cal-rod' heater, A marine pump, 15 gal drum, two ball valves and a inline pressure gauge.
    I'll try to scan the manual so you all can see what's needed.
    I'm sure you can build it of local materials
    Irontite is cheapest in 5 gal drums
  10. godspeedbear
    godspeedbear
    from golden
    I got lucky.. There's a shop, Chaplin Cylinder Heads, That weld heads... They heat the head in a kiln to bright orange, weld up the problems, and bury it hot sand and let it cool slowly for several days... Their rep is pretty good, and they're just about an hour away.
    Calling them Monday.
    Might save the Riley yet!
  11. Crazydaddyo
    Crazydaddyo
