Technical anyone know what this front end is?
Discussion in 'The Hokey Ass Message Board' started by 46convert, Sep 22, 2020.
  1. 34 panel2.jpg Recently purchased project. what front end is this? added a better picture.
  2. Pete Eastwood
    Pete Eastwood
    from california
    It looks a bit like a '54 chevy .
    I also see a crossmember that will accept a transverse spring & a dropped axle !
  3. squirrel
    pretty sure the one in the picture has rubber bushings on the control arms, Chevy was still metal in 54.
    Stebo27 likes this.
  4. Corvair used to be a swap, maybe it's that? Just a guess....
    Sent from dumb operator on a smart phone
    jimmy six likes this.
  5. What's the body?
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    Cut it out. Go back to transverse leaf & straight axle it'll look a whole bunch better at the least .
  7. goldmountain
    goldmountain
  8. B.A.KING
    B.A.KING
    An ugly one...................thats all i gots........sorry
    1stGrumpy, flatheadpete and Deuces like this.
  9. 33 or 34 Ford panel delivery.the front suspension looks like a Corvair. HRP
  10. 31Apickup
    31Apickup
    Corvair or AMC Pacer. In any case that panel deserves a correct spring over dropped axle.
    hidez57 and Hotrodmyk like this.
  11. Daddy_O
    Daddy_O
    ^^^^ Ditto to @31Apickup
    Worthless. If it's your car/project, get it out of there and return it to a spring with dropped axle.
  12. Not Corvair. Lower A frame used a strut like a MII, not a real A arm like shown.
    This allowed Corvair to use a more petite crossmember.
  13. Corn Fed
    Corn Fed
    63/64 Tempest?
    bchctybob likes this.
  14. gimpyshotrods
    gimpyshotrods
    It is a 1961-1964 Carefullyremoveitandscrapit.
  15. jimmy six
    jimmy six
    With full fenders, bumper, lowered, if it works I’d use it. Looks a lot beefier than a M2 or copy which is under everything. I can’t see the steering but it clears everything why not. That’s what hot rodding is all about.
    RJP likes this.
  16. Mr48chev
    All I can figure out is cobbled together. The crossmember and lower A arms look like 49/54 Chevy but the upper A arms are off something else.
    It would be best to cut that 70's back yard engineering off and put something more viable under it.
    MO54Frank likes this.
  17. Marty Strode
    Marty Strode
  18. gimpyshotrods
    gimpyshotrods
    I think that is 1939-1940 Chevy Master Deluxe, or 1941-1948 Chevy passenger car front suspension.
  19. bchctybob
    bchctybob
    Corn fed may have got it, I have a ‘62 Tempest and the front suspension unbolts like a Corvair or early Chevy but size-wise it’s in between the two. I’ll have to look closer tomorrow.
  20. squirrel
    Tempest also uses a strut, the lower A arm does not look like that.
    Stebo27 likes this.
  21. Looks a lot like Pacer...
  22. squirrel
    it's not a pacer
    Speed Gems and Stebo27 like this.
  23. 34Phil
    34Phil
    Give us the wheel bolt pattern and a pic of any brake numbers
  24. squirrel
    how about 61-63 Buick Special or Olds F-85?
    Stebo27, kidcampbell71 and Dan Hay like this.
  25. jimmy six
    jimmy six
    That’s a rear
  26. squirrel
    look at the small picture above the picture of the rear suspension.
    Stebo27 and Blue One like this.
  27. squirrel
    btw I found some pics of a 63 F85 front end, it's not quite the same...metal control arm bushings, not rubber.
    Stebo27 likes this.
  28. banjeaux bob
    banjeaux bob
    from alaska
    Corvair Greenbriar uses an A-Arm
    squirrel likes this.
  29. squirrel
    yup, but they use a 55-64 Chevy car upper arm, and the mystery one does not look like that, does it?
    Stebo27 likes this.
  30. bill gruendeman
    bill gruendeman
    Can’t tell if that’s a rear steer rack (hoses may be ?). Could it be early jag I f s, it’s not later jag.
