Technical Anyone know what these little buggers are for?
Discussion in 'The Hokey Ass Message Board' started by ekimneirbo, Jan 18, 2020.
  1. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Cleaning out an old drawer in my shop and found these. Suspect they are for slipping into some kind of electrical connector but don't know what I would use them for. DSCN1685.JPG
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    those 2 things with the thumbscrews are for plugging trans cooler lines so you can run the car out of the shop while the radiator is out
  3. OLDSMAN
    OLDSMAN
    You are so right they are plugs for cooler lines. The other items I have no idea what they are.
    ekimneirbo likes this.
  4. The second and forth from the left top row are terminal adapters. When you test wires are spade and you want to connect to a post terminal loosen the nut slip the fork under the nut and tighten then plug your Spade into it.
    ekimneirbo and i.rant like this.
  5. I believe the first piece top left is to set spring weight for automatic advance unit.
  6. Boneyard51
    Boneyard51
    Every body beat me too it, but I still don’t know what the top left is?
    Bones
  7. Steve Martin says "testicle clamps". From Dirty Rotten Scoundrels.
    ekimneirbo and anothercarguy like this.
  8. 24riverview
    24riverview
    Just a wild guess, maybe top left is for petcocks?
    loudbang and ekimneirbo like this.
  9. Rice n Beans Garage
    Rice n Beans Garage
    Top left is the Brake hold down spring tool that fits on the end of a ratchet extension 1/4"
    2 sided for different sizes
    loudbang, ted kovacs and ekimneirbo like this.
  10. ................OUCH!!:eek:
    loudbang, hotrodjack33 and ekimneirbo like this.
