anyone from Eagle cranks/installed in line bored block won't turn
Discussion in 'The Hokey Ass Message Board' started by gasserjohn, Mar 7, 2012.
  1. gasserjohn
    gasserjohn
    anyone on here work at Eagle???
    installed a new crank from eagle cranks
    in a line bored block won't turn!?!if you loosened the center main it would turn........checking all the mains there is not enough oil clearance on any of the mains/not even minimum???
    took it to a machine shop he said that mains are too narrow /that is the radius on the cranks are too large he has to turn it 10 under to correct the runout as it was too much &hour glass shape side to side.......
    am calling/email Eagle for their response.......the Quality control from some USA companys suck just sent back roller rockers cause they would of come apart from poor assembly that was very easy to see.............talked to summit they are sending a gift card to cover machine costs&replacing bearings with 10 under set THANKS SUMMIT
  2. Let us now when you hear back from Eagle. I think at least one of them is on here.
  3. gasserjohn
    gasserjohn
    update>>>just got off phone with summit
    was special ordered from eagle
    summit is sending a $150oo gift card & new set 10 under bearings
    they will deal with eagle
    go to you tube eagle cranks to see same type promblem correction
  4. gasserjohn
    gasserjohn
    think it caused by lack of keeping grinding stones true .............
  5. sunbeam
    sunbeam
    arn't they made in China
  6. L larger radius on the journals is a good thing!
    Was it done for a reason?
    Sam
  7. gasserjohn
    gasserjohn
    the dia is uneven as well as the radi is too large for the proper narrow bearings...............
  8. The cores are just cast in China. The cranks are ground here in the U.S.
  9. That's what I thought.
  10. stealthcruiser
    stealthcruiser
    What he said!
  11. falcongeorge
    falcongeorge
    from BC
    Just chamfer the outer edge of the bearing a hair...
  12. Pete1
    Pete1
    from Wa.
    The radius being out of round is wrong.
    The radius being too big is right.
    You modify the bearings to fit.
    Regrind the crank.
    Correct the out of roundness but LEAVE the big radius.
  13. Guy's go to you-tube and type in eagle crankshafts, its very interesting. I have no reason to doubt the shop in Wisconsin and the way he re-machined the crankshaft and his claims. He stated the journal was hour-glass shaped and out of dimension by .0020" That's 2 thousanth's of a inch, not .0002" or 2 tenth's of a thousanth's. 100% unacceptable for a crankshaft journal. TR
  14. Fenders
    Fenders
  15. Balls Out Garage
    Balls Out Garage
    from Arkansas
    I've never had an issue with their products. I'd even say that I've been pretty impressed with some of their machine work. Jimmy and the guys are great and really easy to work with...I'm sure they'd make it right.
  16. falcongeorge
    falcongeorge
    from BC
    Well, yes, thats a whole 'nother issue. And a real serious one. Not the first time I have heard it either. Then Car Craft peddles this "stuff" (not the 4 letter word I WANT to use) on the premise that its more cost effective than machining your original crank.Yea, right "just wash it and drop it in"...:rolleyes:
  17. gibraltar72
    gibraltar72
    from Osseo Mi.
    The larger radius is to prevent craking at a sharp edge a 90 will tend to crack. We used very expensive Callies cranks in sprintcar engines. We also used chamfered bearings.
  18. Heres a little trick of the trade, I'm sure some of you guy's following this thread will enjoy. And yes it applies to the O/P and his connundrum.
    Checking the main bearings " pattern ". Set all of your upper main bearing into the main bearing saddles of the block. Set your crank gently into place in the bearings. Now with a trusty wide tip Sharpie marker, give your self a nice black mark all around the radius of each main journal of the crankshaft. Do both radii now not just one side. Install your lower bearing halves into the main caps, and install the caps, and tighten them down. Establish your end play of approx. .004"-.007" end float or end play. Now spin the crank several revolutions in the direction of rotation. Remove the caps and examine the pattern left in the magic marker markings on the journals. If you find that the crank journal radius has been riding up too close to the edges of the bearing, you can lightly add some chamfer to the bearing edge.
    This would not have helped the O/P with his particular situation, only on a correctly machined crankshaft, TR
  19. ... and made entirely from lead paint, keep it under 5K RPMs....
    Bob
  20. falcongeorge
    falcongeorge
    from BC
    Jeez, thats scary. Can you imagine some guy actually taking one of these, washing it and dropping it in like they say in the magazines?:eek: Cripes, if I got a crank back from a local machine shop like that(and I have) I would have a fit! The list of machine shops I will never set foot in again is long, and the list of the ones I will deal with is short. Scary thing is, alot of the ones I will use the proprietors are getting old, couple of them are well past retirement age.
  21. Don's Hot Rods
    Don's Hot Rods
    from florida
    When I bought the stroker kit for the sbf in my 27 I did some internet digging and saw so much negative about Eagle stuff I went with a Scat kit instead. I can't say it has been totally perfect either, I am on my 3rd rear seal and have even gone a a high performance slightly undersize seal, and it still leaks. Sometime down the road I am going to pull the engine and have our machinist go through the crank to see if the rear seal journal is out of round or what.
    I guess this is why the true high performance cranks cost an arm and a leg compared to Eagle and Scat.
    Don
  22. F&J
    F&J
    Pull the pan and rear main cap, then borrow a magnetic base dial indicator to ride on the seal journal. Or make a simple bracket to hold an indicator, going off a pan bolt hole.
    First thing I'd do, it not assume it's the seal or crank; it could be something else nearby. Might even be leaking past the cap to block surfaces. Look at everything, as or before, it comes apart.
  23. gasserjohn
    gasserjohn
    phone na at eagle on the 7th//they ansered this am said return will replace
    when asked about where machined he said somewhere in calif not at heir shop???wtf!!!.........
    we trust the local machine shop here in sunvalley>w/o us saying anything that the center main was causing the lockup....he found that the centermain was the worst one.....all of the crank was so far off he is having to go to 10under to correct&will give us the correct oil clearance as well.....even with 1 under bearing it was not enough
    i want to repeat on our call to SUMMIT they are sending 150oo gift card tocover cost machine work&taking back the bearings& sending 10under set
    THANKYOU SUMMIT<<<
  24. gasserjohn
    gasserjohn
    btt
    what has been your experience?
  25. Don's Hot Rods
    Don's Hot Rods
    from florida
    Since you mentioned Summit stepping up to the plate, they do that very often, which is why so many people are loyal to them. We had a TCI transmission fail within not many miles, and all TCI would do is fix it if we paid the shipping both ways (and it was determined it was TCI's torque convertor that failed ). We called Summit and they kicked in $ 75 to help with the shipping cost. Have never had any issues with Summit in all the time we have been buying from them.
    Don
  26. If it makes you feel any better a few years back around 02 or 03 I went through 5 cranks from SCAT on a blower motor I was building for a fella. Everything from poor journal sizing to chiped journals. you would have thought that after the first return they would have looked a little closer before shipping.
  27. where I get my cranks done they always have a lot of eagle cranks to do as they don't spec out as received as for large radii it's normal and you have to use narrow bearings
  28. Here is my 2 cents: :(
    I own an engine shop and have been using Eagle stuff about 18 years. The stuff can be good and bad. I see good rods and not so good crankshafts. We do alot of 460 style big block Ford racing engines. The Eagle cranks are not so good. Poor grinding and the counter weights look like they were cut with an ax. Be sure and measure the flywheel flange BEFORE you put it in the block. They are Large and in most cases you can't get the flywheel/flexplate on. We have had to grind that as well as main journals. In most cases the mains are large and we can grind .001 -.0015" and get the clearances we want still using standard bearings. We went to using RPM international cranks. The counter weights are much nicer but we still have to grind the mains and flywheel flange right out of the box.
    Of course when the customer has a larger budget we use Sonny Bryant crankshafts.
    They look so good when you open the box its almost a shame to put it in the engine!;)
    Matt
    http://pro-formancespecialties.com/
