Anybody have SolidWorks at home?
Discussion in 'The Hokey Ass Message Board' started by Beef Stew, Apr 7, 2012.
  1. Beef Stew
    Beef Stew
    from So Cal
    I meant to take care of this yesterday at work but I got busy and never found the time. What I'm looking for is a flat pattern template for a 17.5 degree "bevel" cut on a 7/8" od tube. Basically like this:
    If someone could put this together as a pdf I'd be eternally grateful.
    Thanks!!
  2. LOWBLAZERO1
    LOWBLAZERO1
    i can do it later in the week, if no one else does
  3. Beef Stew
    Beef Stew
    from So Cal
    Yeah, I can do it Monday once I get back to work but I was really hoping to get this done this weekend and not next weekend. Don't ya hate it when one little thing holds up the entire show? Thanks nonetheless.
  4. Beef Stew
    Beef Stew
    from So Cal
    FWIW I need the cut to be 17.5 degrees off the long side of the tube, not the short side.
  5. nofin
    nofin
    from australia
    Print this out so it's 2 3/4" long and you're good to go.
  6. cmbrucew
    cmbrucew
    from Socal
    Beef Stew
    Use a bucket of water, one foot of tube, two foot of angle iron, c-clamp, protractor, and a can of spray paint.
    I think you can see what I mean.
    Works in the field without a computer.
    Bruce
    Works good
    Lasts long time
  7. Beef Stew
    Beef Stew
    from So Cal
    Won't work I'm on a Mac.
    Oh man thank you so much but I'm looking for 17.5 degrees from the long side of the tube, not the short side. Maybe I described it wrong. Call it 162.5. :D
  8. Beef Stew
    Beef Stew
    from So Cal
    trying again...
  9. Doctor Detroit
    Doctor Detroit
    See what you mean? I didn't. Care to explain the procedure for this?
  10. nobby
    nobby
  11. Beef Stew
    Beef Stew
    from So Cal
    Yes!!! Thank you!!
  12. Beef Stew
    Beef Stew
    from So Cal
    He's saying stick the tube into water at whatever angle you want the cut to be at... in this case 162.5 degrees. Then shoot some spray paint on the part of the tube that's not in the water. Obviously you can't spray paint what's under the water so what's left is a nice cut line.
    I thought about doing it this way but setup time alone makes it a deal breaker for me.
  13. nobby
    nobby
    you can of course make a 17.5 degree template to cut the tube, simply by
    dividing 71.5 by 22 gives you 3.25
    take a bit of 2 inch wood, measure along 6 and 1/2 inches
    cut the angle and clamp it to the tube,
    run a straight edge over the angle and tube, then whizz it through with a cutting wheel
