Technical Any vehicles come with disc/drum non power assist?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Feb 13, 2021.
  1. Budget36
    Budget36
    Looking for ideas, I’ve seen some references, but not sure.
    Thanks
  2. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Camaros and Firebirds 69-73
    KK
  3. Budget36
    Budget36
  4. bchctybob
    bchctybob
    My '56 210 has a CPP front disc kit with the stock rear end and a non-power dual Corvette style M/C. Stops great.
    rod1, stillrunners and Budget36 like this.
  5. My 82 Chevy C10 was disc front,drum rear non power brake.Stopped fine.
    325w and Budget36 like this.
  6. ‘66 corvette 4wheel disc no power single piston mc
  7. Some Granadas came with disc front, drum rear non power.
  8. banjeaux bob
    banjeaux bob
    from alaska
    As well as Novas beginning '67.
    Budget36 likes this.
  9. drptop70ss
    drptop70ss
    from NY
    Available on mid 1970s novas as well, I frequently saw them on disco era 1975 up models.
  10. arkiehotrods
    arkiehotrods
    My '40 is non-power disc/drum. Stops great!
    nochop and Budget36 like this.
  11. I had a 2000 Ford Focus front disc/drum rear and no booster. I'm running a mid''70s GM master cylinder with no booster and a '52-56 Ford pedal assembly on my truck. The MC doesn't know or care if it's being boosted by a vacuum booster or mechanical leverage from the pedal arm.
  12. '64.5-66 Mustangs had manual discs/drums with a single-pot master to boot. No 'proportioning valve' either....
  13. Budget36
    Budget36
    Did you plate the firewall on the inside?
  14. xlr8
    xlr8
    from Idaho
    Late 60's to early 80's Chevy and GMC pickups.
  15. Yep.
    Most of the builds we did when I was in a shop were non power assist.
    Didn’t need it with the Willeood stuff
    Frankie47 likes this.
  16. BamaMav
    BamaMav
    from Berry, AL
    71? to 75 Ford Maverick had manual disc front, drum rear, dual master cylinder.
    jimmy six and Budget36 like this.
  17. Mopars....70 up - A bodies are my favorite....
    b-body-bob, HSF and Budget36 like this.
  18. I had a '77 F-100(2wd) with manual disc/drums.
  19. Mimilan
    Mimilan
    S10 Chevy pickup
  20. I was going to say mid 70's Ford pickups. I had a 74 F-100 2wd with disc / drum and no power
  21. F-ONE
    F-ONE
    from Alabama
    70-72 Monte Carlos and some Chevelles of the same period.
    I do believe 1972 was the first year disk fronts were standard on the C 10/Cheyanne
    MO54Frank and Budget36 like this.
  22. Budget36
    Budget36
    Wow, way more info than I got googling it earlier.
    I thank you all.
    VANDENPLAS and 56don like this.
  23. bchctybob
    bchctybob
    No, it’s bolted on with the factory bolt holes and sandwiched with the pedal assembly.
    The car had the full booster, bracket and distribution valve when I got it. Too much crap and no benefit.
    AHotRod, VANDENPLAS and Budget36 like this.
  24. @Budget36 -
    What is your intended application? Pops had a '70 F body manual brakes disc/drum. Used to think it was odd, after reading this thread I guess not.
  25. finn
    finn
    In addition to the already mentioned 65-66 Mustang and late Maverick, add the Pinto.
  26. Elcohaulic
    Elcohaulic
    I had a 1975 Chevy Monza that had manual disc drum brakes. That little bugger could stop on the dime!! The modulation was better... Now I see why my dad hated power brakes and steering.. He didn't like power steering because the steering wheel didn't bounce back after a turn.. He used to say any of his 1930s-40s-50s Fords handled a thousand times better then the new at the time 60s cars. After seeing the alignment settings I see why.
    bchctybob and Budget36 like this.
  27. V8 Bob
    V8 Bob
    Most vehicles had "single pot' masters until the dual system was mandated in '67, and '65-'66 disc/drum Mustangs did use a K/H adjustable proportioning valve, similar to what disc/drum T-Birds and Lincolns also used during that time.
  28. Budget36
    Budget36
    In my ‘57 Chevy PU. Seems like this axle I have uses the early 2nd gen FBody discs as well.
  29. Chevy s10 and ford rangers until early 90’s could be had with manual brakes on the bare bones models.
    I know not hamb friendly, but gives you ideas .
  30. jaracer
    jaracer
    When I worked at a Dodge dealership, I remember an early 80's Dodge D 100. Customer complained that the power brakes quit working. This was after his wife started driving the truck. I lifted the hood and found no booster. I told him the power brakes didn't work because it doesn't have power brakes. That made him mad since he knew it had power brakes. I couldn't convince him otherwise. He ended up trading down to a car for the wife.
    This truck was a disc/drum setup.
