Technical Any trick to separating this?
Discussion in 'Traditional Hot Rods' started by 64Pony, May 9, 2020.
  1. 64Pony
    64Pony
    Been trying to get this thing off for the past couple hours and it’s put up a great fight. Any suggestions? [​IMG][​IMG]
    Thor1 likes this.
  2. ERguitar
    ERguitar
    Pop off the adjustment cover and see if you can see anything.
    Thor1 likes this.
  3. Budget36
    Budget36
    Lift up rear of trans, push in at out a few times
    Thor1 likes this.
  4. There's too much of a gap on top versus bottom.
    You might need help if you're trying to do it by yourself.
    * Attach a tiedown to the bottom and around the jack cup to help pull and keep it on the jack
    "Reverse cowgirl" it so you can:
    * Try to get it aligned by lifting the tail
    * Try to rotate the output shaft
    * And pull
    Wouldn't hurt to:
    * Apologize
    * Talk real nice to it
    You might need to:
    * Lift and push in, first. Keep aligned then pull out
    * Pry it apart at the bottom.
    Dowel pins might be adding to the problem.
    And/or:
    * Get it leveled on wood blocks, hand truck, creeper, or something
    * Work on prying apart
    * You might want to put bolts back in
    * You might want to get some longer bolts in the top holes to help guide it out and keep the top from spreading too much till you get the bottom out more.
    rpm56, kidcampbell71 and Thor1 like this.
  5. Wedge some wood blocks between the trans case and bell to hold it square, then take the inspection cover off and see if you can get some rust spray onto the input shaft/clutch disc spline area.
    Thor1 and fiftyv8 like this.
  6. 64Pony
    64Pony
    This worked. I pulled the cover off and unbolted the clutch from the pressure plate. Transmission came right off! Seems the pilot bearing fused itself to the input shaft.
    I’ll try sweet talking that clutch into giving me my transmission while I grab a beer. Appreciate everyone’s help!
    Tim, David Gersic, Hnstray and 12 others like this.
  7. squirrel
    that's a new one....thanks for showing the cause
    57 Fargo, kidcampbell71 and Thor1 like this.
  8. rusty valley
    rusty valley
    i never understood why they would want an open bearing with all the dust and clutch crap flying around in there
    Budget36, Hombre and Thor1 like this.
  9. 62rebel
    62rebel
    The side facing the clutch is probably sealed. I'm kind of surprised to see actual ball bearing used instead of bronze bushing
  10. Yep, and that is why we use Bronz Bushings. Not the first time I've seen that.
  11. That's a new one. I am glad you found a way to get it apart.
    Bob
  12. Boneyard51
    Boneyard51
    Ball bearings make your synronizers work better! That’s the reason they are there!
    Bones
    bchctybob likes this.
  13. Boneyard51
    Boneyard51
    Most folks have no idea what synronizers do or how they do it! Really, most folks just drive down the road shifting gears when they want to........ NOT when the are supposed to! Anytime you shift ,when you are not supposed to.... the synronizers have to either spin or slow down the clutch plate to match the speed of the engine vs the gear vs the road speed! Not an easy task! So a little less friction in the clutch plate support may help! That is the reason ball bearings are there! Think about it the next time you shift!
    Bones
  14. brigrat
    brigrat
    from Wa.St.
    Boneyard51 likes this.
  15. Boneyard51
    Boneyard51
    I assure you the old input shafts were “ hardened”! To what degree??? I’m not sure. But the were never just mild steel.
    Bones
  16. brigrat
    brigrat
    from Wa.St.
    I should have also said the Iron content of the shaft has something to do with it!
  17. pitman
    pitman
    A roller bearing w/a shield might serve, I'd pause before using a sealed bearing in high temp places
  18. alchemy
    alchemy
    Original Fords used a bronze bushing, not the ball bearing. So I'd think the inputs are hard enough.
    I once disassembled a rusty 99 Merc block from its transmission. The clutch disk was rusted solid to the input. And the engine and transmission were stuck too. There was no way to save both the block and the transmission, so I broke the bellhousing off the transmission so I could remove the bolts from the pressure plate. Saved the special block though.
    5window and pitman like this.
