greetings again fellow HAMBers!...are there any experienced builders in the Scranton area willing to lend a little guidance to a newcomer?...Email Ed on here posted about some suspension work he is doing and may benefit from someone local to him helping him out a little.....
Not sure what you consider Scranton area, but there is Phoenix Hot Rods in Hacketstown NJ about 2 hours South of you.
I appreciate the reply paintman!...actually I am n south jersey,I was inquiring because there is a fellow on here from that area who started a thread called " my rear ended is too big" and is doing some chassis work with no experience and no guidance but seems like guidance would be a good thing!....he is in the Scranton area....
He will need a good welder and fabricator, to remove some bad work, and re-do it properly. He jumped into a big job, with too little experience, too little research, and the wrong tools. Someone out that way needs to help him on his way.
I'm in Wilkes Barre(30 minutes out) but, I have very limited experience in the type fabrication he needs. As Clint Eastwood/Harry Callahan once said, "A man's got to know his limitations"
