Ok, don't have the cash to get all the old molding holes filled on my 53 ford customline. I like the look of the car without the old molding on it. I painted her sky blue. Any ideas on how to mask, cover or disguise the holes? I'm thinking sticker flames would be shitty looking....lol!
You already painted the car?,,how about duct tape? Seriously,,,unless you use some sort of stick on black or chrome molding to run from the front to the rear of the car or individual plugs to fill the holes would be the only option I can think of. HRP
Drill more holes all around them so it looked like you made them on purpose..or maybe tint some bondo with your paint and fill them that way!
Well, the right way to do it would be to grind the paint back off, back the holes with a piece of copper, and either fill them up with weld, or weld in small pieces of sheetmetal to fill them. A less desirable, but sometimes workable way to do it also would be to use body filler - I've read lots of bad about it but I've also seen bigger rust holes filled with it with no obvious ill effect.
Get some of those spikes that are on dog collars .... that would look really cool PLUS it would keep the squeegie-man away from your car. ... just a thought.
Nothing you can do that won't look like hell. just leave them,and if you ever paint again,weld them shut first. I'd much rather see the holes than some halfass attempt to fill them.
You put the cart before the horse. I suggest putting the trim back on. Otherwise, weld the molding holes closed with plugs and repaint. Filling the holes with bondo won't last. I welded the molding holes closed with plugs on my '55, ground flush, very light coat of body filler, primer, later painted.
after reading the responses, I guess just leaving them is the way to go...not to say there weren't some funny ideas..lol..dog collar spikes...LOL, bullet hole stickers...LOL...funny shit.
If you don't want to weld the holes. You could cut some small patches of metal and use 3M panel bond to attach them . Then a small amount of filler and of course primer then paint.
I must admit I'll never understand taking chrome off a car and filling the holes unless it's to put moldings from another make on it. I guess my thought are why would you want to make your car look like a cheaper one. You have a Customline, why turn it into a plain jane Mainline? Polish out your trim and put it back on!
