hola i own a 50 ford f-1 pick-up which is mostly stock except for engine,trans, rear end. used to be a old hot rod running around the south bay area in california. well anyways i have a broken leaf spring and i was wondering if a 55 ford f-100 leaf spring would fit as a replacement? well if anyone could help me i'd appreciate it thanx alot
beatup, You talkin' front or rear? Main leaf or one of the others? If it's rear, I might be able to help you out if you're willing to pay shipping. I've got a '48 F-1 panel truck. I broke the right rear main leaf at Bonneville this year. This morning I obtained both complete rear spring packs from another F-1. So maybe something that I will have left over will help you. Send me a pm and we'll discuss. As for the F-100 fitting I can't help there. What Rocky said...
not sure about rears ,know fronts are longer after53 i have a friend that blew apart a f-1 in santa rosa , what do you need? ill ask...
