Anti-Squeak Question
Discussion in 'The Hokey Ass Message Board' started by Super88, Oct 26, 2013.
  1. Super88
    Super88
    I decided to clean up the area behind the grill and in front of the radiator on my 55 Olds. I've noticed in the manual that it calls for the use of anti-squeak in several areas where parts are bolted together. Is this some type of tape or gasket and what is a good source for it?
  2. fordflambe
    fordflambe
    Back when I was a kid and had no money, I used Scotch rubberized electrical tape (not the vinyl) as anti-squeak on my 31 chevy. It is still on the car and has worked very well. Went this way because no-one makes any of that kind of stuff for a 31' Chevy.
  3. drptop70ss
    drptop70ss
    from NY
    Most of the stuff I find on tear downs (or what is left of it) looks a lot like roofing tar paper. Anything that will keep metal off metal will stop squeaks.
  4. 325w
    325w
    from texas
    The cloth tapes works well.
  5. greg32
    greg32
    from lemont,IL
    On my 32, found remnants of what looks like tar paper between wood and steel.
  6. Ya know, on my 41-46 Chevy trucks there's lots of areas that would squeak if not for anti-squeak material. I found an old serpentine belt works great. I just cut, and glue in place with that yellow weather strip adhesive. :D
  7. unkledaddy
    unkledaddy
    Nylon fender washers.
  8. Gman0046
    Gman0046
    Make your own anti-squeak out of an old inner tube.
  9. Bert Kollar
    Bert Kollar
    Today the automakers use a lot of closed cell foam very thin
  10. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I use electrician's "friction tape". It's sold in rolls in hardware stores and is cheap. Works great.
  11. 5559
    5559
    from tn
    all sounds good, but the inner tube is easy & cheap & wont screw up your alignment of your sheetmetal -at least it worked good for me
  12. gimpyshotrods
    gimpyshotrods
    I use left over leaf spring liner.
  13. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I also use inner tubes for stuff like that, or when it needs to be extra neat looking i get rubber/neoprene washers at ace hardware.
  14. Super88
    Super88
    Thanks guys. Nice to know there are different options depending on whether it will show or not.
