History Another Survivor Surfaces
Discussion in 'Traditional Hot Rods' started by Mark Jenny, Mar 8, 2019.
  1. Mark Jenny
    Mark Jenny
    ok...will do that..sounds like great advice!...Thanks
  2. Mark Jenny
    Mark Jenny
    the one in the top pic was for sale on flea bay awhile back...I was very tempted to pull the trigger!
  3. Mark Jenny
    Mark Jenny
    That is a real cool old car that you have there!!!...I love old hot rods!!
  4. lowbar
    lowbar
    from Indiana
    If you change cam shaft and use the 265block cam needs oil noch on rear journal no notch no oil pressure
    olscrounger, loudbang and Mark Jenny like this.
  5. I am not seeing a shield under the carbs. Unless there is a metal plate/gasket under the carb itself (aside from the carb gasket). If that is the case it is supposed to keep the carbs from heat soaking.
    @Tim I saw this the other day. pretty slick. The old price is funny, the motor is worth more than the asking price of the car way back when.
  6. RiffRaffRoadster
    RiffRaffRoadster
    Well yours is awesome, and looks to be in better shape that mine when I took it out of storage. Plus, you can actually take your whole family for a ride when the car is finished! I’ll be lucky to fit just my wife and I in the roadster.
    Please don’t make the same mistakes I made! I gave it to a local builder before I knew what I had and they media blasted off the paint and completely dis-assembled the car. Then I joined this site and discovered some of the history. My advice is to drive it, take lots of pictures of current condition, and fix/ improve it a little at a time. I’ll be following your posts-thanks!
  7. jimvette59
    jimvette59
    Nice find!!!!!!! Roman Red that is the color of my 59 corvette.
  8. Mark Jenny
    Mark Jenny
  9. Mark Jenny
    Mark Jenny
    The builder obviously loved red corvettes!!
  10. Mark Jenny
    Mark Jenny
  11. Mark Jenny
    Mark Jenny
    Where do I buy new rivets to put it back on?
  12. 56sedandelivery
    56sedandelivery
    That auction site we all know and love, or any of the Tri-Five/Corvette vendors. They twist out counterclockwise, may have to file flats on opposite sides of the rivet heads to get a grip on them. Tap them back in with a small hammer.
    I am Butch/56sedandelivery.
  13. Mark Jenny
    Mark Jenny
    Thanks Butch
  14. Ford52PU
    Ford52PU
    from PA
    such a great car and story, really enjoy following your progress. Congratualtions! Go buy a lottery ticket your on a roll.
    Mark Jenny likes this.
  15. Mark Jenny
    Mark Jenny
    update...starting to reassemble the motor now...heads are back on...intake on...Butch..you can see where we blocked off the crossover on the intake...everything was clean under the shield....exhaust manifolds are on..radiator removed and flushed..now back on..new radiator hoses ,fan belt and NOS fuel pump...if all goes well should fire it sometime this week...in the meantime I'm taking apart the old wood roof new kit from Macs on the way..that's my buddy Larry in the pics torquing the heads and adjusting the valves,,,BTW Butch, I was wrong...solid lifters not hydraulic.. IMG_2146.JPG IMG_2147.JPG IMG_2148.JPG
  16. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    Good for you Mark. I look forward to seeing it. Sam
    Oldioron, Mark Jenny and loudbang like this.
  17. 56sedandelivery
    56sedandelivery
    Ya'll see how much better 265 intake gaskets fit on a 265, rather than 283/327/350 universal gaskets; compare to his tear down pics. Those little tin covers they supply with gaskets set usually don't last long; they burn through. It's why I said I was going to have the dual quad intake I have actually welded up at the crossover. I like your oil pump primer! Fire er' up.
    I am Butch/56asedandelivery.
  18. Mark Jenny
    Mark Jenny
    Thanks Sam...hope your doing well...
  19. Mark Jenny
    Mark Jenny
    Thanks Butch...we actually made the inserts, they are a bit heavier gauge than the ones you buy...they are aluminum as well...I dont put many miles on my car, so hopefully they out last me;)
  20. Wow what a bitchin car! I'd love a car like that!
  21. Rice n Beans Garage
    Rice n Beans Garage
    Looks like the cars in great hands
  22. Welderboy60
    Welderboy60
  23. Mark Jenny
    Mark Jenny
    Thanks..it's been exciting bringing her back to life
  24. Mark Jenny
    Mark Jenny
    Yup...I can actually fit in this one:D
  25. Mark Jenny
    Mark Jenny
    Thanks...I love old hot rods!
  26. flamingokid
    flamingokid
    That car is some kind of wonderful !
  27. classiccarjack
    classiccarjack
  28. Mark Jenny
    Mark Jenny
    might get a chance to fire it tonight....
  29. 51box
    51box
    from MA
    So cool man what a score!
