hey guys my dad and i are building a car together and it started tonight this is my forst car i am building from scratch and should be fun using a 32 frame and 30 model a coupe body. i have a 41 merc flatty with alloy heads and triples and thats what we started doing tonight getting it into place so we can start building some engine and gearbox mounts i will try get some pictures up as we go. should have the front end in before the end of the weekend cheers dylan
The motor is pretty well stock just with some Repo edelbrock heads and triple carb manifold im using 40 ford front end and rear end with split wishbones have a 3 speed and coloum change also a 40 ford coloum Cheers
Sat the front end under this chassis tonight will set up the quick change with the diff we are using this weekend and sit that in there ready to mount up all we need to fit front end is some new perch bolts and different spring as the 40 ford ones sit in front of the i beam.
Can't believe I missed this one, that is a sweet little mill in that thing! looks like you are putting together a very nice pickup, both of them are nice! Doc.
front end sitting in there with dummie wheels waiting on spring got perch bolts today etc and rear end sitting in the back need to make some new shock mounts and also got split wishbone kit today so progress is going well as soon as the diff is mounted we will take it out and set up the quickchange wooooohooooo playing with the camera caddy and a flatty cant get much better than that huh??
Looks like all the right stuff, going to cool!! I saw your pickup at the swap, very cool also and will keep an eye on this build.
Cheers mate will post more pictures as we go. Got the weekend off finally after going hard for 6 weeks straight so should get some shed time this weekend
Body arrives in the country tomorrow which we brought off a hamber in las vegas neat guy with a cool caddy speed parts collection, we did however manage to get a manifold valve covers and this body off him. Body isnt in to bad nic chop has been started and is unfinished as you can see we have all the original chopped out bits so can decided on how much we want in there Posted using the Full Custom H.A.M.B. App!
