Technical Another item added to the what the heck is this?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 27, 2020.
  1. Steering wheel puller.
  2. Handle from an arbor press?
    3W JOHN likes this.
  3. LOU WELLS
    LOU WELLS
    from IDAHO
    Hex Headed Revolver?...
    3W JOHN likes this.
  4. mgtstumpy
    mgtstumpy
  5. Thanks guys, once it was pointed out it is obvious as to what it is. HRP
  6. 5window
    5window
    I
    It made me curious about who the heck KR Wilson was. This site looks like an interesting way to spend a 100 degree afternoon! http://krwilsontools.com/
  7. Wrench97
    Wrench97
    Interesting site, it's a shame he doesn't tell us what happened to the company after 1948.
    3W JOHN and HOTRODPRIMER like this.
  8. pkhammer
    pkhammer
    K R Wilson Tools are highly sought after by early ford mechanics. They made a lot of specialty tools for Model A Fords and such. Many of their tools bring some very good money.
  9. This is another item that was found when helping to clean out a estate. HRP
    3W JOHN, ct1932ford and chryslerfan55 like this.
  10. Wanderlust
    Wanderlust
    Makes me think impact screwdriver
  11. B62C81AE-9220-414F-932C-67B7B93A0875.jpeg Easy
    Being Italian the first thing is a handheld spaghetti maker
    the second one is a ravioli sticher
    3W JOHN, ct1932ford, blowby and 2 others like this.
  12. TrailerTrashToo
    TrailerTrashToo
    "BACK OFF ONE TURN" sounds like good advice to me.
  13. studebakerjoe
    studebakerjoe
    HRP looks like an automatic trans band adjustment tool
  14. arkiehotrods
    arkiehotrods
    3W JOHN, VANDENPLAS and HOTRODPRIMER like this.
  15. studebakerjoe
    studebakerjoe
    @arkiehotrods I'll take that as a compliment. Thanks. Yes it's true lots of knowledge on here.
  16. 3W JOHN and VANDENPLAS like this.
  17. hoop
    hoop
    HRP The one you have is for old cast iron Ford Cruise o Matic. The bar is put under the adjustment screw for the band as a spacer. The chain is so you don`t lose the bar.The tool is set to freewheel at the correct torque .Then back off one turn .Tighten the lock nut on the adjustment screw and your done.
    Okie Pete, 3W JOHN, 62rebel and 8 others like this.
  18. Thank you both, I appreciate the replies. HRP
    3W JOHN and chryslerfan55 like this.
  19. Like an M2 headspace and timing gauge. :p
  20. 37slantback
    37slantback
    Danny, I see you are staying busy. Thats some very interesting auto archeology there.
  21. Yes sir and thanks to some members with a lot more knowledge than me and willing to share their expertise we are able to describe just what the items are used for. HRP
    3W JOHN likes this.
  22. studebakerjoe
    studebakerjoe
    Were there any hydra-matic tools by any chance?
  23. We are still digging through all the crates & boxes, the estate has 3 large quonset huts, and we are just getting started in the first one, this is where we found these two items. HRP
  24. studebakerjoe
    studebakerjoe
    I'll post some pics of tools so you know them when you see them.
    3W JOHN likes this.
  25. studebakerjoe
    studebakerjoe
    20200801_181356.jpg These are Hydra-Matic tools. If you find any of these I'd certainly be interested in buying them.
  26. 73RR
    73RR
    ...plenty of folks around here have no idea who Ma Duece is.....or what she is capable of.;)
  27. You had to bring it up. So here is what it is used on. Problem Solver.jpg
    Headspace and timing gauge are used to do what they are named after. First you set the headspace between the breech and the bolt by screwing the barrel in or out until the gauge fits in the GO end and the NO GO end will not fit. Then you insert the GO end to set the timing with a wheel and the rear cover removed so it will fire at 600 rounds per minute when the bolt is completely closed. Failure to properly set the headspace and timing can result in a, worst case scenario case rupture causing severe damage to the gun and user. Best case it will not fire.
    And if you have a bigger problem.
    M 134.jpg M134. 18,000 Rounds per minute
  28. When the $h1t gets real.
    And when all else fails.
  29. jimmy six
    jimmy six
    Here are both of the adjustment tools for the Cruise-O... the “bar” as you call it has measurements on it 2C60E359-3CFB-40FA-84B2-D32C772C0D28.jpeg F8138EAD-DBFC-45AA-AA5C-0674023D1D09.jpeg
