Projects Another Henry J project started
Discussion in 'The Hokey Ass Message Board' started by earlj02, Nov 11, 2010.
  1. After driving a 53 Henry J with a small block Chev 40 thousand miles with original suspension and drum brakes, it's time to build a refined version of the same car. But i bought this one in 1967 and drove it when I was 16. It's time.
    Here is a a pic of my old car and the start of my new car. i want to have it on the road by May 2011 and will post pics as I go along
  2. First job was a Fatman front end. The rear is Maverick. The frame is not boxed from the axle back. The easiest way to box this was to cut the parts out of another HJ frame and presto perfect boxing plates This would work for any car
  3. Maverick rear end needed pads moved in 1/4 inch on each side.and brake line block moved to HJ location As I go along some of this info might help some one
  4. So what's going to power this one ?
  5. It's been one month since I started this build Here are Nov. pics and I will post each month until I fire this up
  6. saturday engine pull getting ready to transfer body
  7. Here is an update on my HJ I'm fixing rust and more rust but it's coming together You do what ever comes next and It works out Here is some pics
  8. modelkitbasher
    modelkitbasher
    slam the car to the weeds add about a 750 horse smallblock ford or chevy and hold the hell on playboy.
  9. Time for a little update. The floor is pretty much done, I had to rebuild up to 5 inches on each end of the door post Lots of work but each day is closer. I made 3 outriggers on each side , the factory used 2. The body is off the frame now and I installed a cowl to place the engine and trans. more later
  10. nwx
    nwx
    from Tacoma, WA
    Nice Build!
  11. jammersspeed
    jammersspeed
    from herman mn.
  12. Wow Now the floor is done and I put it back on the frame. Now a stock HJ frame you can put a small block Chev in about a day. Modernize with a fatman front clip and now there is no room for an engine unless you set it back alot. the crossmember is high and right at the sump. Now What ! I raised the trans tunnel 2 inches, cut the crossmember and made my oil pan Here is the pics
      49.1 KB
      42.1 KB
      58.9 KB
      71.9 KB
  13. ironandsteele
    ironandsteele
    Cool! Henry J's are so bitchin!
  14. Here's more
      48 KB
      55.3 KB
      49.2 KB
  15. And a few more 3.25 gears and traction lock is installed in the 8 inch
      58.8 KB
      66.2 KB
      66.1 KB
  16. hustlinhillbilly
    hustlinhillbilly
    from ohio
    Used to be a guy down here in southern Ohio, that had a Henry with a 413, dual fours and a 3 spd. Had the engine set back far enough that the driveshaft was only about 10" long. Definite thrill ride when he'd punch it.
  17. Here is a few more pics as of June 1st The seats are from a 62 Pontiac but I still want a bench seat
  18. NTAPHSE
    NTAPHSE
    Looking really good!
  19. Here is one more pic
  20. MikeHJC
    MikeHJC
    from Michigan
    I didn't know you were redoing the Henry. Nice Job
  21. I haven't posted an update for a while so here are some pics I will be on the road this spring
  22. Progress on your J is looking good, getting closer to a spring time drive. I like looking at that some what stock firewall to see what mine should have looked like...lol
  23. After 45 years there is some life back into my Henry J
  24. My rat Henry J is going quite nice and I will have it up and running in a few weeks here is a few pics
  25. Another engine pic
  26. HotRod60F100
    HotRod60F100
    You radiusing the rear wheel wells?
  27. chevy3755
    chevy3755
    nice job on the j..........
  28. Nice work!
    Safe to say, you have the only Henry J in Prince George?...and Sunbeam Tiger??
  29. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Always fun to see other "J"s,Good Job,I had built mine in 1959 with a V8 olds as a dailydriver,then I cut the roof off and a lot of other stuff,it ended up as a show car in Car Craft in Jan.63.:cool::D
  30. falconwagon62
    falconwagon62
