Technical Another 60 Pontiac block code question
Discussion in 'The Hokey Ass Message Board' started by RT468, Dec 28, 2020.
  1. RT468
    RT468
    Can't seem to find my paper copy reference materials and internet searches are coming back lacking. Probably my wording on the search I'm guessing. So I pose this question to the collective gurus,what's the 6 after the M4 code signify? Slightly different size and font than the EUN and code 20201224_172640.jpg stamping. M4 is readily identifiable but I'm assuming the 6 is either a trans upgrade or added option designation. Or it just a case of being added or mistake for unknown reasons? Should be the last block related question I'll have for a while. Next in line will be crankshaft questions (missing digits and D proceeding partial part # as one example) but I'm trying to pace myself. 20201228_153750.jpg
  2. treb11
    treb11
    the 6 digit number is the design drawing that the casting was made to. I recon the 6 is an inspection stamp, independent of the M4, which is the specific rating the engine was assembled to. M4 is a 1960 or 61 389 tri-power with 3-speed manual trans rated at 348HP. What are the date codes near the distributor hole?
    More info here:
    Engine Codes – Pontiac Power Net
    wvenfield and Deuces like this.
  3. RT468
    RT468
    Thanks for the info. The date on the block is D 28 0. I had looked at Pontiac Power and Wallace Racing and found the M4 code but didn't see anything refencing what looked like the hand stamped digit following it. I had originally thought it was an A4 with 6 until I cleaned it up a bit. That seemed odd as that denotes a lower hp engine and this block is a 4 bolt. As shallow as these stamps are I'm a bit leery to do anything else to abrasively remove the rust and crud.
  4. Duck's Goat
    Duck's Goat
    block.jpg What you have is a very rare block. It's a 4 bolt 389 tri power engine also known as a 425A. The 6 is factory done and indicates it was a 4 speed manual transmission application. Only 722 cars were built in 1960 with the manual 4 speed, I have one of these blocks myself.
    Elcohaulic and Deuces like this.
  5. Deuces
    Deuces
    I'd love to see a picture of the bottom end of that block.....:)
  6. Duck's Goat
    Duck's Goat
    Elcohaulic likes this.
  7. Duck's Goat
    Duck's Goat
    RT468 do you have a pic of any numbers like these on the front of the block? They’ll be below the ones you posted a pic of. 113010DD-723B-441A-A3EE-783061B0C5C8.jpeg
