Projects Another 54 Chevy 210- 4 Door Budget Build
Discussion in 'The Hokey Ass Message Board' started by EnragedHawk, Jul 27, 2020.
  1. EnragedHawk
    EnragedHawk
    from Waco, TX
    Hi all!
    Picked up another project and want to start documenting it here and also ask a lot of questions. I picked it up a couple weeks ago, but wanted the title situation settled before I put any work into it. I now have a title in my name, and I’m ready to get started.
    I ran across this 54 Chevy 210 on the interwebz. Long story short, I got the car for $500. It’s incredible just how complete it really is. It came with the seats, all the glass, all of the trim (or so it seems this far), fairly solid floor (needs a few patches), engine, transmission, head and tail lights, door handles, plenty of stuff I’m forgetting, and even the original bumper jack.
    My goal is to budget build the car as is. I’d like to run the original 235 and three on the tree. Paint won’t really be an option, but I plan to strip the car to bare metal anyway. If it gets lowered, it’ll be blocks and cut springs most likely (at least for now).
    I’ve already got a list of questions, but wanted to get the basic intro for this project done first. Hoping to really dive into it next week. I’ll
    Likely pull the engine and trans first and see what I’ve got to work with.
    I’ll also be video documenting for anyone interested:
    Now at home:
    Matt55folife and AHotRod like this.
  2. Squablow
    Squablow
    What's the giant valve in front of the distributor?!
    Glad the car is being saved. Shame it's apparently seen a lot of exposure already but certainly looks fixable.
    EnragedHawk likes this.
  3. 302GMC
    302GMC
    from Idaho
    Home Depot Ranco valve ..
  4. EnragedHawk
    EnragedHawk
    from Waco, TX
    My guess is a makeshift heater control.
    craig b blue likes this.
  5. carolina chevrolet
    carolina chevrolet
    That looks more like surface rust than primer to me. That one should be fun to rebuild, parts are plentiful for those. I'll be watching this thread.
  6. EnragedHawk
    EnragedHawk
    from Waco, TX
    Oh yeah, definitely a lot of rust.
  7. FRANK GRELLE
    FRANK GRELLE
    i will be watching! love this stuff!
  8. EnragedHawk
    EnragedHawk
    from Waco, TX
    It’s not much of an update, but thought you guys would appreciate this.
    I hit up my nephew the other day. He’s a car guy but doesn’t have much mechanical experience yet. I thought he’d like the opportunity to learn. Lord knows I like the opportunity for free minions.
    The first night they started at 8pm and stopped roughly 4am. The next night they had it out in a couple hours. I didn’t do anything but help them guide the engine out.
    They did a fantastic job!
  9. EnragedHawk
    EnragedHawk
    from Waco, TX
    Well, it’s a start. Still haven’t gotten the engine on a stand yet. Hopefully soon. It will turn by hand, so that’s good.
    Matt55folife and simplestone like this.
  10. EnragedHawk
    EnragedHawk
    from Waco, TX
    Compression is all over the place. This is new to me, and I’m sure it’s a quick google search (which I’ll do next), but anyone care to chime in on what my next move should be? I figure the engine could run like it is, but not well. I need to check oil pressure too, but don’t have a spare gauge handy.
    Here’s the compression check for anyone savvy:
    [​IMG][​IMG][​IMG]
    Matt55folife likes this.
  11. RMONTY
    RMONTY
    A couple of stuck valves maybe. Pull the valve cover and check the rockers and make sure the valves are moving freely. PB Blaster on all of them!
  12. EnragedHawk
    EnragedHawk
    from Waco, TX
    So, I let some oil sit in the cylinders, and this is the best set of readings I got:
    Cylinder 1: 155
    Cylinder 2: 155
    Cylinder 3: 135
    Cylinder 4: 115
    Cylinder 5: 140
    Cylinder 6: 150
    There’s obviously something up with 4. 3 and 5 still off as well.
    I have tried that yet, but I did get a look at the valve train. It “looks” ok, but that’s not saying much.
    Should I be getting oil from this tube when cranking? I’m not seeing anything currently. I’ve got an oil pressure gauge, just need to get it hooked up.
    [​IMG][​IMG]
  13. RMONTY
    RMONTY
    3 is ok, 4 is a bit low, 5 I wouldn't be concerned with but they all may come up if you can get it started. You arent going to see oil like you would on a SBC, but you should see some oil oozing around the rockers. You can pull the distributor and spin the oil pump up with a drill to see if you are getting oil pressure. You will have to make an extension to match the tang on the bottom of the distributor out of an old screwdriver or similar.
    Truckedup and EnragedHawk like this.
  14. EnragedHawk
    EnragedHawk
    from Waco, TX
    Didn’t think about using a drill. I’ll for sure try that!
  15. RMONTY
    RMONTY
    What are the casting numbers on the head and block?
  16. EnragedHawk
    EnragedHawk
    from Waco, TX
    Head is 3835913 and the block is 0249299F54. I think it might be from a truck.
  17. EnragedHawk
    EnragedHawk
    from Waco, TX
    Spent a little time this evening on the car. Getting closer each time! [​IMG]
    Haven’t messed much with the engine yet. I want to start getting things out back together before make a bigger mess.
  18. trevorsworth
    trevorsworth
    It really is amazing what a wire wheel can do for a car.
  19. Looks pretty darn solid. That's gonna save a lot of work, and give you a good base for painting it.
  20. EnragedHawk
    EnragedHawk
    from Waco, TX
    Got the 235 to fire up!
    Multiple thing I should mention before you start getting on to me...
    Yes, the engine should have been better supported.
    Yes, leaving the fan on there was dumb.
    Yes, we probably ran it on starting fluid longer than we should have.
    BUT IT RUNS!
    Matt55folife and MO54Frank like this.
  21. Baumi
    Baumi
    Congrats on getting your engine running!, Yeah, kind of a sketchy setup, but I have done dumber things myself...you lived to tell and that´s what counts.
  22. EnragedHawk
    EnragedHawk
    from Waco, TX
  23. EnragedHawk
    EnragedHawk
    from Waco, TX
  24. MO54Frank
    MO54Frank
    Cool old car. Keep going, you’ll get there.
    It is fun to get an old motor that’s been setting a long time to run. Congrats.
  25. What a transformation with the flap wheel !!!!
    Pretty much rust free.
    Cool car
  26. RMONTY
    RMONTY
    I hope you were wearing a mask when you were stripping all the tetanus off that thing!
  27. EnragedHawk
    EnragedHawk
    from Waco, TX
    Alll done! Kinda...
    I still want to hit a few spots again. I’ll probably go over the whole car with a different brush.
    I need to finish up with the engine. Might slap some paint on it. Next I’ll clean up the engine bay. Also need to start looking for door latches. I think I only have one of four.
    Matt55folife and Sandgroper like this.
  28. EnragedHawk
    EnragedHawk
    from Waco, TX
    Been a little busy with the car. Man it’s tough staying in a budget. Haha I should seriously sell the car right now. In its current state, I can probably make the biggest turn around on my money.
    Anyway, pulled the clutch and flywheel. Had the flywheel turned.
    I was going to order a new clutch, but the shop that did the flywheel said is be better off having it rebuilt. I didn’t even know that was a thing. Anyway, I’m a little spent out for right now, so that will wait.
    With the engine able to fire up, I cleaned and painted it up. I wanted to throw it back in the car this week, but I really want the transmission back together first. The paint was free, so black it is!
    Worked on getting the frame cleaned up. Pulled the master cylinder out too.
    I figure I just need to get the clutch pedal action working smooth again then throw it back in. I’ll be putting a firewall master cylinder on instead, so I don’t need the brakes working.
    Also I finally went through all the crap in the trunk. Lots of stuff! Only obvious missing thing so far is the rear driver door latch. Hoping I still run across it. They seem to run about $50 shipped on eBay. I’d rather not do that.
    Anyway, lots of work and not much to show for it. Decided to throw the front clip all together as a sort of motivation booster. Looks pretty sharp. At least in my head. Haha
  29. EnragedHawk
    EnragedHawk
    from Waco, TX
    My stupid Olds kept me from getting much done on the 54. Now that it’s fixed, I got a little more done today. Been parts gathering too.
    Picked up a brake master cylinder, booster, proportioning valve, and pedal assembly for $40. The assembly will take some modifying to make work, but I’m going to try and set it up like the kits that come from Speedway Motors where it bolts to the firewall panel.
    I had a one wire alternator sitting on the shelf, so I modified the generator bracket to adapt to the alternator. That’s a lot of trouble for an addition 6 volts. Haha
    Hopefully can start getting the brake pedal assembly mocked up soon.
  30. Tall t 26
    Tall t 26
    Solid project !!
    Looking good.
