And now a flathead question.
Discussion in 'The Hokey Ass Message Board' started by Ghost of ElMirage, May 18, 2012.
  1. Ghost of ElMirage
    Ghost of ElMirage
    :confused: I am about to buy an original set of flathead spark plug wire looms for my 59A motor (it's a 39 or 40 block I believe) with a two bolt dizzy. The guy down in FLA says he has a bunch of different sets that are different lengths. So which do I tell him I want? And if it matters I am using a flat or "crab" style cap. Thanx for all the help as usual guys and gals
    Ghost
  2. forty1fordpickup
    forty1fordpickup
    The 59A block should be 42-48. The 2 bolt "crab" dizzy is right for that year range. Up to 41 used the "divers helmet" style dizzy. Those are commonly three bolt mounting.
  3. Saxon
    Saxon
    from MN
    Crab dizzy has two cross over wires. So the looms will have one hole on the inside of the looms and 2 on the outside.
    Divers are wired 4 left/4right.
    Not sure on difference of loom lengths.
  4. Saxon
    Saxon
    from MN
    Here's a couple engine picts I have with the different looms.
    1: is a 59ab. Crab (you'll see the 2 wires crosses over the intake)
    2: is a 38 221 Helmet.
  5. alchemy
    alchemy
    Get the ones with the shortest front ends. That way you'll have more room to maneuvre the wires to the correct side before you jam them up your tubes.
  6. Ghost of ElMirage
    Ghost of ElMirage
    Thaanx all you guys and SAXON thanx to you for the firing order!! LOL
  7. Saxon
    Saxon
    from MN
    It's not the firing order it's the wiring that is different. 3 and 5 cylinders are the ones that make the loom different. The firing order is the same. Lol
  8. Ghost of ElMirage
    Ghost of ElMirage
    DUH I really need to lay off the scotch lol
  9. Saxon
    Saxon
    from MN
    Ah... You have scotch?:D
    You could probably run the other looms with extra wire, but if you have a choice get the one you need. Other Might be tough on the dizzy side as mentioned.
  10. Ghost of ElMirage
    Ghost of ElMirage
    Are you a friend of my friend Scotch? We are close and have known each other since I cheated on Bourbon with Scotch.
  11. Saxon
    Saxon
    from MN
    I'm a simple beer guy and okay with a grain shot. Been known to take a tumbler when offered.
    And the closer I am to the beach a rum runner calls out.
  12. Ghost of ElMirage
    Ghost of ElMirage
    BIIIIG fan of beer myself i never turn one down lol
  13. 48fordnut
    48fordnut
    You need the short ones. Going thru the same problem, I need a set also.
    Thanks,
    jim
