AN fitting color removal
Discussion in 'The Hokey Ass Message Board' started by 31coupe, Jan 5, 2013.
  1. 31coupe
    31coupe
    from saskatoon
    Is there any way to remove the red or blue color from AN fittings. I have two on my tri carb intake and would like to lose the color on them. I read in a magazine once that you can remove the color but I can't find that article.
    Any info would help.
    Thanks.
  2. 60srailjob
    60srailjob
    from nowhere
    arn't they just anodized?
  3. ssaza25
    ssaza25
    from arizona
    I have used Oven Off. Works good for me.
  4. 3wLarry
    3wLarry
    from Owasso, Ok
    Actually...it's Easy Off oven cleaner.
    kidcampbell71 likes this.
  5. Model A John
    Model A John
    from wichita ks
    Use drain cleaner that has lye in it. Mix one part cleaner to two parts water in a container that you can put your fittings in. After the fittings have been in the solution for a few minutes, the solution will start to boil. It might take about 10 minutes or so for the anodizing to be stripped. There will be a black residue on the fittings. Wash the fittings in clean water, using a tooth brush to scrub off the residue. Make sure you don't leave the fittings in the lye solution too long, because they will get eaten away quickly. Ask me how I know!
  6. Deuces
    Deuces
    This must be a traditional thing huh???...:rolleyes:
  7. 31coupe
    31coupe
    from saskatoon
    Yes! We're all out of our minds!:eek:
    Thanks guys for the replies.
  8. ^^^ This ^^^
  9. 60srailjob
    60srailjob
    from nowhere
    why don't you just put a wire brush in the die grinder and remove the anodized color
  10. harleycontracter
    harleycontracter
    I've buffed it out
  11. fenderless
    fenderless
    from Norway
    As said, use drain cleaner, but watch the fitting ones and a while, as the quality of the anodizing is diffrent with diffrent manufactorers.
    You don't wanna hurt the metal itself. Clean in tap water, and buff abit,
    then they be nice abd shiny:)!
    Taildragger&fenderless
  12. Harrisontx
    Harrisontx
    from Waco Texas
    I believe Hot Rod Mag showed using just a wire wheel...
  13. NINE INCH
    NINE INCH
  14. rat nasty
    rat nasty
    I've heard easy off.
  15. Not sure if it is the same but muratic acid removes plating off of fasteners.
  16. 1931modela
    1931modela
    from montana
  17. Pete Eastwood
    Pete Eastwood
    from california
    Easy Off oven cleaner, I've had good luck with it on anodized fittings.
  18. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yep, Easy Off. It works like magic.
    Don
  19. Hnstray
    Hnstray
    from Quincy, IL
    You might check with some of the aviation supply houses for clear anodized fittings.
    As I recall, the anodizing 'hardens' the surface of the aluminum, it isn't just for appearance sake that it is used on fittings.
    Ray
  20. Deuces
    Deuces
    Aman!!!!....
  21. Quain Stott
    Quain Stott
    Don't take the anodizing off the threaded part or the flare it could cause problems later.
  22. 60srailjob
    60srailjob
    from nowhere
    sould have went and got different ones?
  23. Old Tin and New Tin
    Old Tin and New Tin
    If I can only find the fitting in red and blue anodized I have been glass beading the fitting and then buff it back out. Works better than chemical removal attempts I have tried.
  24. 60srailjob
    60srailjob
    from nowhere
    never tried that?
  25. truck
    truck
    from Brisbane
    Any caustic based product, oven cleaner, draino etc.
  26. alphabet soup
    alphabet soup
    I used the wire wheel on my bench grinder. It also kinda polished the fittings.
  27. OLDSMAN
    OLDSMAN
    I can't remember the manufacture that does it, possibly Earls, but they now offer a black finish. As it was said this not only for decoration, but to harden the soft aluminum metal
  28. Lucky3
    Lucky3
    Fast and easy with no mess. Put the plastic or aluminum AN plugs in each end prior to keep the inside un contaminated as you don't want to take the anodized coating off of the inside.
    A wire wheel on a bench type grinder works very well also without any chemical mess.
