Technical aluminum slot lug nut help
Discussion in 'The Hokey Ass Message Board' started by Dan, Dec 8, 2016.
  1. Dan
    Dan
    I have searched and googled but am coming up empty. Can anyone steer me towards where I can buy these? Need ten. The wheels have an "A" on the center cap so I assume they are "American" or "Appliance" brand?? Thanks-
  2. squirrel
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. Bert Kollar
    Bert Kollar
    ezaccessary.com has about every lug nut ever made
  6. squirrel
    maybe you meant, that they have about every lug nut now being made? They don't have the old designs.
  7. Dan
    Dan
    3/4 shank is the one I need, the ones I posted in the pic look like they would be too short in the shank...
    I would prefer they were the "long" ones, as the center flange of the wheels is pretty thick and the lug nuts are recessed in quite a ways...
    I did try it though and I could use "short" ones by using a thin wall socket...
    Got to thinking maybe the "A" could mean Ansen as well?? The back of the wheel says Japan, if that is any clue??
  8. henryj1951
    henryj1951
    from USA
  9. squirrel
    The style of the A is Appliance.
    Also, center caps are easy to change...does the wheel say anything on the back, besides "made in japan"?
    How deep is the recess around the nut?
  10. squirrel
  11. squirrel
    henryj1951 likes this.
  12. henryj1951
    henryj1951
    from USA
  13. squirrel
    they don't have the kind that is pictured in the first post in this thread, do they? They aren't being made any more. The ones you pictured are the same as the second ones I posted a link to.
  14. 53 ford
    53 ford
    If the wheels are made in Japan, you may as well go to O'Riley's and buy them.
  15. Dan
    Dan
    The recess for the lug nut is 3/8 deep on the hub side and 37/64 on the tire side. The mounting flange is 3/4 thick so the 3/4 shank with a washer does give me what I need, I think...
    the back of the wheel has stamped on it-
    12 27
    Japan 8002A-2 14x7 47A
    Was pleasantly surprised to see that the fronts will clear the disc brakes
  16. metlmunchr
    metlmunchr
    The wheels are Appliance. Made in Japan and the counterbored lug holes make that a sure thing.
    I doubt the lug nuts in the first picture are original from Appliance. Could be, but I've got lug nuts from Appliance slots I bought new around 1972 and they're not the extended hex length like the ones in your drawing. FWIW, the only thing you get from the extended hex is the ability of someone to slap an inpact socket on them and beat the chrome to death. The shorter originals do require the use of a standard wall socket because an impact socket won't go into the counterbore.
    The shank length in your drawing is correct in that it matches the originals I have. The ones from Summit Squirrel linked to in his first post should function the same as original.
  17. squirrel
    I'm not quite sure I understand what you're saying about the recesses....can you make a dimensioned sketch of the cross section of the wheel, in the lug nut area?
  18. bowie
    bowie
    They are Apliance Plating like Squirrel said.They were the only ones to use the long hex with a short shank due to the lugs recessing into the wheel. I tried to find some years ago , with no luck.
  19. Try Summit Racing. measure your shank depth and get your lug diameter and call them on the phone. 1 800 230 3030 Contrary to popular belief the phone is still your friend.
  20. metlmunchr
    metlmunchr
    Jim, the counterbore is 3/8 deep X just large enough to barely clear the 1.062 washer. The length of the thru hole, measured from the base of the c'bore to the back face of the wheel is the 37/64 he mentioned. There is no c'bore on the back side. The thru hole is sized to clear 11/16".
    The washers are stamped from either 11 ga or 10 ga, so either .120 or .134 thick. Either one will leave too much shank length when installed on a 3/4" long shank.
  21. squirrel
    so he needs a short shank (.55" long)
    thanks for the clarification
  22. jimmy six
    jimmy six
    Gorilla lugs on line
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Before anyone thinks it, don't, not even you Jim. If a squirrel was to be picky about it's nut's. It would surely die before finding it's perfect meal.
