I'm looking for a Grant steering wheel adapter for my 1960 Cadillac. I purchased a part#3162, but the center hole is not large enough. The shaft is 1/2inch.Grant says they no longer make an adapter. Can anyone HELP? The red metal flake wheel is waiting
On my 59 the splined section is conical which is the problem. I took a 60's Chevrolet one and had a machine shop ream it out to the Cadillac size , but they could not spline it. So I bolted in on tight and impressioned the splines, removed it, then got to filing. Quite a few hours later it was on, I had more time that day than money. There is a turn signal metal tang piece under the wheel which need grinding down as well. Some people say to get a old wheel and cut out the center but there is not enough meat for the 3 bolt pattern to do it safely
