Technical Aftermarket A/C control light help
Discussion in 'Traditional Customs' started by ZZ Top Chop, Feb 18, 2019.
  1. ZZ Top Chop
    ZZ Top Chop
    image.jpg image.jpg Over the weekend I cut out a engine turned panel for my A/C controls. Man do I have a greater appreciation for making these, took forever. While putting it back together I accidentally pulled the wires off the back of the bulb (soldered in). There is no socket, just a bulb with two wires coming out the back and is held into the back side with a rubber grommet. After searching the net, I was unable to find something similar. Any thoughts where I can find these or something similar? Guessing this was a very low wattage bulb due to the thin wire size. The a/c system is an off brand Vintage Air-ish made in China unit (so you know it's good). Bulb is the diameter of a 15/64 drill bit.
  2. GearheadsQCE
    GearheadsQCE
    Can you just solder the wires back on?
    Boneyard51 likes this.
  3. Gman0046
    Gman0046
    Looks like an aircraft 327 bulb.
    Gary
  4. ZZ Top Chop
    ZZ Top Chop
    The wires were pulled out inside the metal cap and I can't get the bulb apart.
  5. jerry123
    jerry123
    Vintage air has them with wires attached
  6. Gman0046
    Gman0046
    jerry123 has it right. Vintage Air sells replacement bulbs with wires attached.
  7. ZZ Top Chop
    ZZ Top Chop
    You're the man Gary, Thanks
  8. ZZ Top Chop
    ZZ Top Chop
    Thanks Jerry, I'll check it out.
  9. ZZ Top Chop
    ZZ Top Chop
    So I went to eBay, Summit sales these with the leads which is the Vintage Air bulb supplier (Proline Replacement Bulb 20557 VUP). Thanks for pointing me in the right direction, guys.
