Customs Advance Adapters 712548 with '96 Camaro WC T5?
Discussion in 'The Hokey Ass Message Board' started by slo-dat, Jun 17, 2019.
  1. slo-dat
    slo-dat
    from Coulee, WA
    1. Upholstery
    As the subject says, I'm trying to figure out if Advance Adapters 712548 bellhousing will mount a '96 Camaro WC T5 (1352-247) to a '66 327. I want a hydraulic slave cylinder to use with my Walton Fab clutch pedal setup in my '54 Chevy.
    I appreciate any help on this. I have googled, and searched for hours and this looks like an option. I already have the transmission.
  2. Did you ck with Advance?
  3. slo-dat
    slo-dat
    from Coulee, WA
    1. Upholstery
    I did check with them. Hoping to find a solution..
    I may have to make my own adapter.
  4. el Scotto
    el Scotto
    from Tracy, CA
    I used a steel scattershield, drilled the Ford bolt pattern into it and welded threaded slugs into the inside of the scattershield
    If you have to use a hydraulic throw out they are available as external push or pull type and there’s the internal type that replaces the throw out bearing.
    slo-dat likes this.
