Technical Achey BRAKEY question ...
Discussion in 'The Hokey Ass Message Board' started by da dodge brother, Aug 19, 2019.
  1. da dodge brother
    da dodge brother
    from wisconsin
    BRAKE QUESTION ... Can a dual master cylinder that has the different size reservoir's, intended for disc/drum set up, be used on a drum/drum application. Do you need an adjustable proportioning valve ????
  2. Doublepumper
    Doublepumper
    from WA-OR, USA
    It can be used, providing the maser cylinder has the proper bore size and doesn't already have residual valves installed for disc/drum brakes. Typically, adjustable proportioning valves aren't needed for drum/drum setups.
