Acetone, are there any advantages or disadvantages to use it to clean a spray gun? Is it better or worse than lacquer thinner? Ago
Depends on what you've shot thru the gun. I use laquer thinner, but don't leave it in the gun for a long time, it can damage the o rings and seals. Flatman
When in doubt you can use the thinner or reducer of the paint you sprayed. Lacquer thinner will always work.
S/P told me to use acetone to clean my spray gun if I sprayed slick sand....I think it cleans better than lac thinner.
I think that some lacquer thinners contain acetone; which would make it evaporate faster. I use acetone, but it does evaporate a lot faster than lacquer thinner.
There is not a set formula for lacquer thinner, so it's not all the same. However, lacquer thinner, especially if it contains MEK, is a more aggressive solvent than acetone alone.
