Accessory Fan 16” Heavy Duty Cooling Six Blade Flathead V8 City: Virginia Beach State: VA Price: $125 Hard to Find Six Blade Ford Accessory Flathead Fan Hub Assembly. Perfect for increased cooling in a traditional hot rod, vintage racer, SCTA or Bonneville Salt Flats car. Not the 18” truck part, the fan is 15 ½” across the blades with a 2 3/8” deep spacer and 3 1/8” hub bolt circle. The rivets are tight, the blades are straight and there aren’t any cracks or dings. I put a tape measure in pictures so you verify it is right for your application. Plus shipping. Thank you.
