It is interesting that you needed that many shims with the zephyr springs and the Chevy valves. I have the same springs and Chevy stock replacement SS valves and I came up with 55 lbs on the nose with no shims. Maybe it is because the manly valves are a little longer? Thanks, —louis
Louis, I was surprised too. I don't know what's different on my motor than others that have done the same thing with the same parts. I believe i'm doing the process correct though.
Measured all the parts this morning, all the parts are the normal size. I found the install height is longer than most. My installed height is 2.185, which is .205 longer than most. 3, .060 + 1, .030 shims = .210 which is right at the .205 longer than most. The only difference I can think of is the valve seats are lower than most.
Ok guys, still plugging along. I had some issues with cam bearings and had to take the motor back to the machinist. I have been assembling the Coupe while waiting to get the motor back, so a little progress there too. Aaron
Aaron, get yourself a dead blow hammer for whenever you need a little persuasion, instead of using a steel hammer. That steel against steel, that aint good. https://www.homedepot.com/p/TEKTON-Dead-Blow-Hammer-Set-3-Piece-30709/205561479
Hey Aaron - looks like you're doing some nice assembly work - keep after it! You should have a really nice running engine when you're through.
Thanks Dale, Blues, Tim and Brian, I'm learning as I go. Blues4U, I thought about you when I was tapping in that shaft, haha. I do need to get a dead blow hammer though. Alright, enough chit chat, it's out to the shop to install some pistons! Aaron
Aaron, what you're doing is really great. This series of videos will be so helpful to a lot of guys doing what you're doing. I hope my comments never make you want to stop doing it, I'm only wanting to help where I can.
More engine assembly. I haven't had much time to work on the Coupe lately, but every extra few minutes I have, I try to get something done on it.
How I missed this thread is beyond me but wow awesome thread and videos are great. Keep the updates coming.
Good luck with the move! As for the flywheel, you should be able to use an 8BA flywheel and matching pressure plate with the correct clutch disk for the ‘39 style trans. Call Fort Wayne Clutch and Driveline. (https://fortwayneclutch.com/) Folks on the Ford Barn recommend them and they should be able to set you up. I know they sell a kit for your setup. —louis
baspinall, ya, kinda sucks to have to give up the big shop. Thanks for the info Louisb. Thanks nailheadroadster.
Good luck with the move!! And thanks for the Videos.. Looking forward to when you get settled in and more progress on your sweet little Ride!! George
Intake is just set on with a few bolts, radiator, grill shell and grill are on. Sent from my iPhone using H.A.M.B.
