Projects A V/8 parts gathering. New pics /eng pics B
Discussion in 'Traditional Hot Rods' started by 48fordnut, May 16, 2017.
  1. WTF really
    WTF really
    Every step no matter how small is a good thing. Your doing great.
  2. 48fordnut
    48fordnut
    And here I am after 3 mos of having the roadster back, finally getting something done. Eng out ready for f/w. With all the moving and inactivity I can't find the f/w bolts. I did find a couple of keepers from a couple of summers ago.
    The cleanup has been profitable for me ,I found a 271 Hi Po ford dist. Must be from 35 yrs ago when I had a 64 fairlane.
    Past couple of mos have been hectic, not being able to get about.
    New caregiver and some working time.
    Starter coming.
    Randall, OFT, Stogy and 1 other person like this.
  3. Cliff Ramsdell
    Cliff Ramsdell
    Jim,
    Good to see you back at it again. Happy new Year to you and Joy.
    Cliff Ramsdell
    48fordnut likes this.
  4. 48fordnut
    48fordnut
    Thanks Cliff. Happy New Year to you and yours.
    jim
  5. 48fordnut: What transmission crossmember is that by the way?
  6. The black and white roadster may be from Mass. The chopped 1942-46 Ford coupe in the background looks like Magneto Magazine owner, Tony Dow's.
  7. 48fordnut
    48fordnut
    Trans cross member ,modified F1 with modified F1 Pedals.
  8. dirty old man
    dirty old man
    Jim, I found and read your comments about the transmission preferences and I have one I'll give to you if you can use it.
    It's an aluminum case 4 speed (4th OD) from an OT '79 Mustang V8. No gears "stripped or busted", but after 200K+miles it would drop out of 4th into neutral without warning and sometimes jumped out of 1st on launch. I replaced with a T5 which is a much better trans with a more favorable ratio spread.
    It does have a tailshaft and housing quite a bit longer than the trans you show.
    It will need some TLC, but it's yours if you want it.
  9. 48fordnut
    48fordnut
    Thanks Dave, I'm committed on this one.
  10. glamb
    glamb
    Jim, haven’t been on here much lately except for browsing the classifieds. Glad to see you’re still at it!
  11. WTF really
    WTF really
    Glad to see you are still making progress. One step closer. Keep up the good work.
  12. 48fordnut
    48fordnut
    There has been progress, just not reported. This winter has been harsh on this old man.
    On to the progress. My frame was zed before I had the Tardel book. This meant once under the car a sub frame cross member had to be cut out and moved fwd. Pics show.
    With a flat head, how many more leaves do I need to put in the spring pack?
    Hopefully more progress near future.
  13. Willows
    Willows
    For what its worth i have 8 leaves in mine, plus armstrong shocks (which do a surprising amount!). Changing the arch of your main leaf can do alot for you also.
  14. Willows
    Willows
    Jim, just had chance to read your whole thread! Really great work, thanks for sharing.
    48fordnut and WTF really like this.
  15. Slick Jimmy
    Slick Jimmy
    from Eden NY
    Nice build! Thanks for sharing. Gives me inspiration.
  16. 48fordnut
    48fordnut
    The rotating blades have hit the project.
    Bad situation last night with wife. she couldn't/wouldn't go to sleep. I did some reading and thinking. My zeed frame is completely wrong. The rear axle would be about 4- 6'' fwd of what it should be. I simply did not have the Tardel book, or enough experience to do this right. It shows how to do this in the book.
    With my wife's condition, I'm going to step away from this for a while and take care of other things.
    Thanks for all that have followed, with words and acts of encouragement.
    Cliff Ramsdell and chessterd5 like this.
  17. WTF really
    WTF really
    Take a break. It will be there when you have the time. Come back rested with a big hammer and it will fall into place.
  18. TCATTC
    TCATTC
    Maybe things will move along smoother now.
  19. 48fordnut
    48fordnut
    Certainly hope so. Got it out of the van on saw horses. That was a chore. Used a wagon for the back side of the frame.
  20. TCATTC
    TCATTC
    Please keep us updated with pics
  21. 48fordnut
    48fordnut
    LMK if you find the shock mount.
  22. 48fordnut
    48fordnut
    Couple of pics from the shop. Backwoods Custom in Twin City Ga. Gave me an assist on the frame.
    Tim the owner did a great job for me. I have since sold the original zeed frame. I need the body mount that goes under the cowl, the one that has 2 bolt holes thru,3 rivets to frame.Where you adjust the A pillar.
    This is where I am today. sat,29 may.
    Thanks for looking,
    jim
    20210529_182851.jpg 20210529_182914.jpg 20210529_182942.jpg 20210529_182959.jpg
  23. 48fordnut
    48fordnut
    Trying to make more room. I have torn a work bench down and rebuilding the wall. Sheetrock is a whole nother game, esp for one person. Should be back on th car by the w/e. Going to drop the eng in and ck for clearances.
    I checked on the price for a small argon tank for mig 200 plus tax. wow.
  24. 48fordnut
    48fordnut
    Almost a month. Joy is doing somewhat better , meds change.
    Now for the good news. Shop is almost complete. .This was supposed to happen on Sat, put it off till today.
    Eng is close to correct position, not hitting firewall and ft axle not moved. Pick up the gas bottle tomorrow.
    Finally moving fwd. Thanks for all the moral support.
    Jim.
    WTF really and TCATTC like this.
  25. TCATTC
    TCATTC
    Lookin good! Wish I was close enough to help you with the heavy stuff. Is that 8BA heads on a 59AB block?
  26. 48fordnut
    48fordnut
    No, its a 8cm Merc block converted to the 59A crab dist, cam, gears .Etc..
    I wish you were closer also Tim.
    Just finished putting my new dropped Okie Joe axle together.
  27. 48fordnut
    48fordnut
    I have made some progress, even though it's not much. Changed frame and ft axle, mounts welded in, up in the air about trans ,63 ford 3 speed with a jeep top, or a fresh 39 trans. Tomorrow is the day for the 63 trans.
    need opinion on the grill guard.
  28. OFT
    OFT
    I like the stone guard. I run one on the oft as I drive on dirt/gravel roads at times. Helps with the rocks thrown up by other vehicles.
