Technical a shocking question
Discussion in 'The Hokey Ass Message Board' started by flatheadgary, Jun 13, 2020.
  1. flatheadgary
    flatheadgary
    from boron,ca
    when you make mounts for shocks how far out do you pull them? half or 3/4 or less.
    hemihotrod66 likes this.
  2. Joe H
    Joe H
    2/3 compression, 1/3 extension when mounted in as driven position.
    mgtstumpy and hemihotrod66 like this.
  3. Your question made no sense to me. I am glad Joe H. figured it out. I was trying to think, Half or 3/4 of what? Inches, Furlongs, Dichfors....
    The 1/3 rule Joe mentioned is good, and works well with standard automotive fair. In the heavy truck industry, almost all suspensions are set with nearly equal amounts of jounce and rebound. So the shocks would ride at the mid point of their travel at ride height. Of course, most heavy trucks are air ride with the ride height controlled with either height control valves or electronic control valves. The off road guys prefer to go with even more ride in, often 60% rebound or more. This keeps the tires in contact with the ground over rough terrain at high speed. Trophy truck suspensions are on the extreme end of the spectrum. All depends on what your building.
  4. flatheadgary
    flatheadgary
    from boron,ca
    i kind of figured you all would know i was talking about a hot rod car. this is a car site isn't it?
  5. Dirty Dug
    Dirty Dug
    Keep in mind when measuring that on a new build the car will settle about an inch or more in the first few hundred miles of driving.
  6. SDhotrod
    SDhotrod
    A good explanation of what you're wanting help with always helps to get your question answered. We can't read your mind or see what you're working on if you don't post pics.
  7. flatheadgary
    flatheadgary
    from boron,ca
    so what your saying is i have to paint you a picture?
    firstinsteele likes this.
  8. SDhotrod
    SDhotrod
    Well I tried, have fun building your, whatever it is...
    4doorfever likes this.
  9. 4doorfever
    4doorfever
    How dare you try to understand a poorly stated question before offering advice that was solicited. That'll teach ya.
    Sent from my LM-V405 using The H.A.M.B. mobile app
    SDhotrod likes this.
  10. Except when you're talking about stagecoaches :rolleyes:
    SDhotrod and Desoto291Hemi like this.
  11. LOL! I knew.
    Ben
  12. 1pickup
    1pickup
    Grammatically speaking, your question asks how far out do you pull the mounts. So, since we mostly speak English here, it's easy to understand why few can understand your question. Maybe try this: "I am building new mounts for my shocks. I need to know how far the shock should be extended, so I can get the correct length of the mount. Thank you in advance for your input."
    At over 700 posts, you should probably have a handle on how this place operates by now.
    1933_willys_77 and SDhotrod like this.
