Projects A rebuild from a bad build
Discussion in 'Traditional Hot Rods' started by dsiddons, Apr 3, 2019.
  1. WB69
    WB69
    Oh my, those pictures are actually scary looking!
    Xtrom and classiccarjack like this.
  2. someone on here said "it ain't yours unless it made you dirty" so I'm guessing it will be yours by the time it's done.
  3. missysdad1
    missysdad1
    Making the rear lower won't help the great "stance" this car already has. If anything lower the chassis equally on both ends so the rake angle isn't changed. IMHO it's just right the way it is, channel job and all.
    But...before you get to removing much more of the gawdawful mess that's been made of the subrails and floor, be sure to weld in some conduit bracing so that the body does not collapse or twist. It looks like the body is already quite weak and you don't want to make it worse by handling it too roughly without adequate bracing.
    There are quite a few examples of channeled cars being built here on the HAMB. It would be good for you to review them before you start constructing a new foundation for your body. There are good ways and there are bad ways and it's handy to know what is what before you get to buying materials, cutting and welding.
    And, if it's not already been done, take the time to box the frame while the body's off. The car will no longer have the structural strength of the subrails/stock floor so boxing the frame will help reduce the body's tendency to twist out of shape when going over uneven ground like driveway entrances.
    My beater coupster (avitar) had been cut up much like your coupe so I've already been where you're going and have learned some of the pitfalls you'll encounter. Good luck!
    dsiddons likes this.
  4. Wheeliedave
    Wheeliedave
    I agree Rich but I think it is "dangerously" low
    Dave
  5. Kiwi 4d
    Kiwi 4d
    The PO should be banned from ever molesting an old car again.
    You are sure taking the right path and fixing bad the correct way and asking questions.
    Hope tou did not pay a premium for the car.
    But now you own it , so it will be done right.
  6. Hummmm I wonder ?
    Looks like I’ve seen that work before
    gas & guns and dsiddons like this.
  7. dsiddons
    dsiddons
    from Indiana
    Looking this thing over a bit I found chrome Arrow Headlamps. At first glance I thought they were just some cheap Chinese stuff. The grill shell I think is a 32’ truck because the insert and shell it all one piece. I think the axle is a old drop also. The body is the biggest challenge. Frame is nice and seems straight and has some cool cast wishbone radius rod mounts. Intake is Weind high rise with 97’s.
    classiccarjack likes this.
  8. rustyrods
    rustyrods
    from Dixon,Il.
    That's an old school hotrod. Run what you brung. Hang on and scream like a girl !
    norms30a likes this.
  9. I love the stance on your hot rod...well the workmanship is very old school for sure...please keep us in the loop as things go along...love the full height top on it...you will be able to actually see stuff when the time comes to drive it...
    MikeC
  10. Hang in there Dave. When its done you will know exactly what you have. I have uncovered some of the same type of sin and evil in a few of the cars I have had over the years. It is a good feeling when its all fixed to know that you have a solid ride under your ass.
  11. 41rodderz
    41rodderz
    from Oregon
    Hind sight is 20/20.:oops:
  12. Bandit Billy
    Bandit Billy
    It's a machine, it can be fixed. Hell, you are like me you will get more enjoyment out of fixing/building this thing than if you had just bought a nice little driver that didn't need you. Save those pictures, someday you will look back and laugh your ass off while you are driving a cool little hot rod.
  13. 57JoeFoMoPar
    57JoeFoMoPar
    Yeah, you can see a lot of the work is pretty sketchy. The thing that sucks about getting a car in the condition is that usually you pay the price for a running and driving car but wind up doing the same amount of work to fix it as if you bought a non-running shell. I've found it tends to work that way with real estate, too.
    dsiddons and 31Vicky with a hemi like this.
  14. put the steering box on top of the frame, and your steering will be good, put in metal floors a section at a time and boom, no more mud on you, grind and weld up the structural cracks and go ridding around.
  15. haileyp1014
    haileyp1014
    from so cal
    Hope it came w vasaline
    loudbang and dsiddons like this.
  16. OLSKOOL57
    OLSKOOL57
    You are so right! The fixing/building (frustrating at times) is most enjoyable.
    Bandit Billy, loudbang and dsiddons like this.
