Hi,up for Sale is a Pair of Used Ford,Holley 94 2 Barrel Carburetors. Carbs can be Used on all Flathead V8's with a 3 Bolt Flange.Can also be Used on Multi Carb Intakes,Flathead V8,Early Cad,Oldsmobile,Buick Nailhead,Early Hemi,Small Block Chevy,Etc. Specifics on Carbs. Holley,Ford,Model 94,Type 59,2 Barrel Carburetor,15/16,H Venturi,Markings on Carb & 8BA-15/16,H 3 Bolt Base Cast AA-1 Details on Carburetors. I took Carbs Apart & Cleaned & Checked them,Reassembled with all there Original Parts,all Threads are Good,all Stock Linkage works Perfectly. Choke Plate Operate's Perfectly,as well as the Trottle Shafts.Fuel Inlet Threads are Good.I Polished them Up for a Clean Vintage Look,too me they Look the Best this Way! These Carbs will need a Basic Kit as they need Gaskets and i would Replace the Power Valve,they come with a New Simple Kit. More Information These Carbs would be Perfect for a Dual Pot Intake,Like a Flathead V8,Chevy 283,327,Early Cad,Olds,Buick Nailhead,Early Hemi,Etc. A Friend a mine Runs an Early Cad V8 with a Dual Pot Intake and 2 Holley 94's in his 34 5-Window Coupe with Apsolutely No Problems.These Ford 94 Carbs work Excellent for Multi Carb Set Ups and Look Fantastic very Vintage Looking.If you are Building a Vintage Hot Rod or Custom and want to Run Mult Carbs,don't let these get away.Shipping will be 15,PM for Questions,Thanks.
