A/C compressor questions...
Discussion in 'The Hokey Ass Message Board' started by JK, Dec 13, 2009.
  1. Every A/C compressor I see is the Sanden type.
    My 93 350 has this type:
    Why do most people use the sanden type?
    Can I use the bottom comp with an aftermarket A/C unit?
    If not, can I get a sanden with a serpentine belt pulley?
    I'm just looking for ideas and answers. Thanks
  2. hotrod-Linkin
    hotrod-Linkin
    that's what comes with most vintage kits these days. must be cheaper. also bracketry may be easier to fab.
  3. hotrod-Linkin
    hotrod-Linkin
  4. Edsel_Presley
    Edsel_Presley
    A/C? What's that?
  5. R Pope
    R Pope
    Compressors are pretty much interchangeable, as long as there are hoses available to fit the other components.
  6. Domino
    Domino
    The Sanden 508s are small and reliable. The R4 pancake compressor on your 93 is very common on GM vehicles. They fail often and are known for their "black death" feature. They leave pieces of their internals throughout the system. The Sanden one is available with a serpentine clutch. The mid 80s Jeep Cherokees use them.
  7. Jimv
    Jimv
    A/C compressor? now thats old school!!
    Jimv
  8. It's what keeps the wife happy on the way to Austin.
    Lighten up, Francis. Am I building your car?
  9. Vintage and other suppliers sell the fittings to fit OEM compressor to aftermarket systems.
  10. 325w
    325w
    from texas
    sanden unit is the best for a hot rod. it works great pulls very little hp. alan groove has the brackets and it comes in v belt are serpentine. stay with sanden not the knock offs. ask me how i know. old air hs a bracket to use the sanden along with your bracket.
  11. I will look into that. Thanks.
  12. 29nash
    29nash
    from colorado
  13. allengator
    allengator
    from Keller, TX
    I have the modern compressor on the serp belt set up on my new engine that I am about to drop into my 66 chevelle....
    Both CLASSIC and VINTAGE air companies said it would work just fine and they will sell an entire kit MINUS the compressor and sell and adaptor to make it work!
  14. BlueGhost
    BlueGhost
    I kept my Ford compressor when I put the classic auto air system in my truck. My 302 is from an 89 Mustang so I wanted the keep the compressor that worked with my serpentine set up. When I ordered my A/C sysetem I told them what I wanted to do, and they sent the lines without the compressor fittings crimped. Then once I had everything installed, I just went to a A/C shop and had them trim the lines and crip the fittings on the for the compressor.
  15. lowmaster
    lowmaster
    Ask anyone that works on cars that are not hot rods and they will have their own horror stories about those pancake compressors. Yes, They will work with just about any system but be sure you use a brand new one and not a rebuilt. Also the key to having one last is to make sure the viscosity, amount, and type of oil is correct for your compressor. In my opinion the 508 compressor outperforms the R4, and we do have mount kits to adapt them to stock GM Serp Brackets.
  16. Found it!!!
    It's the vintage air PN#141805.
    Thanks for the help.
  17. Jimv
    Jimv
    Gee Wiz Sgt.Hulka i just ain't never seen a A/C unit on a "traditional" hotrod!!!
    JimV
  18. B Blue
    B Blue
    Don't know about the million or so other guys, but I used the Sanden for its compact size, easy to fabricate mounts for, wide range of pulleys and reputation for long life.
    Bill
  19. hotrod-Linkin
    hotrod-Linkin
    i run an a/c because i can't afford a traditional divorce,,and i'll listen to her ...she has the purse strings!!!
