Technical A 265 Chevy build with a cool story
Discussion in 'Traditional Hot Rods' started by bfalfa55, Jul 23, 2013.
  1. dblgun
    dblgun
    I am for sure to an engine guru but if your setup ends up needing it I have used/use GM .016-.018 shim gaskets with aluminum heads and have had no issues with them. Make sure that everything is flat, use good fasteners and make sure of your torque values. It will depend on where you end up with deck, piston/head clearance and all the other things you will want to consider to maximize quench while avoiding "things" getting together. You can get MLS gaskets from Cometic and others that come in around .025-.027, I have used hem also and they are nice, I also think the fire ring is fine at the edge of the bore as long as there is not overhang and obviously as long as you get a good seal. I would like to see a picture once you have time to post one to see exactly what you're dealing with.
  2. bfalfa55
    bfalfa55
    Hey dblgun, look back in this thread on PAGE 7 in about the middle of it, I have pictures (the first one is probably best) posted where you can see how the tops of the bores were modified.
  3. Gary Addcox
    Gary Addcox
    Man, you and your Son are so lucky to have your Father/Grandfather to not only offer advice but help with your builds. Hang in there, guys ! I am reliving the "good old days" when the 265-283 were kings. They still are to me.
  4. dblgun
    dblgun
    Yeah bfalfa I remember the photos you posted then, I was wondering about photos where the gaskets you were speaking of are shown on the block.
  5. bfalfa55
    bfalfa55
    I reordered my gaskets and will have to run a 4.125 bore, .039 gasket. This will give me a .054 quench and 10.15:1 comp. Taking .010 more off the block will put me at .044 and right about 10.5:1. I don't know if doing that is worth it or not for the effort. Thoughts ?
  6. dblgun
    dblgun
    If you're certain about those compression figures, make sure to take the camshaft's effect on dynamic compression into consideration.
  7. bfalfa55
    bfalfa55
    I will most likely be choosing from some other cams because I think the lift the first Lunati rep recommended won't give em enough valve to piston clearance. The other 2 I am looking at have a calculated 8.41 or an 8.71 dynamic compression ratio. Do you think it is still safe enough with the 8.71 running 93 pump gas ?
  8. dblgun
    dblgun
    Common reasoning is that greater than 9:1 dynamic compression ratios are normally race engine territory. Obviously like so many other things with cars and engines there many opinions which are based on what you are willing to do/put up with. I believe that your plan is to run aluminum heads with a more modern design combustion chamber which should allow you to run more compression. Maximizing quench will also make your engine more compression tolerant. As you already know the more compression you can get in that little engine the better. In my opinion you can run the dynamic compression at 8.71 and with the proper tune and fuel mix you should be able to make it work fine.
  9. bfalfa55
    bfalfa55
    Thanks dblgun. I was thinking much the same, it's just good to hear it from others who have knowledge and know the little engine has to be approached different and a little more precise with the right combo of parts!
  10. bfalfa55
    bfalfa55
    Based on where my cam RPM range is 2,300-6,300 RPM, .218/.228 duration @ .050, .503/.503 lift. 112 LSA hydraulic roller, do any of you think I will benefit from an X pipe or an H pipe in my 2 1/4 inch exhaust system ? I read some conflicting information as to how it may benefit or hurt my little 265. I would like to hear your suggestions or if you think it isn't worth the effort at all.
  11. sololobo
    sololobo
    what a cool info load in this thread, love the 17 year old being interested in the build. I went with my my brother to pick up a super clean little 265 last year, it is lurking in the corner of his garage wanting to run again, it will. All this info is super. Thanx to all sololobo
  12. sololobo
    sololobo
    again I must say this great thread has more info than google!!
  13. bfalfa55
    bfalfa55
    Yes it does and you can thank all on the HAMB for their input. Unfortunately, I have made this a long, drawn out affair but it probably has allowed every question and answer someone could need or want to build a 265 or even a 283 get asked.
    504640 likes this.
  14. Roothawg
    Roothawg
    So, whatever happened? Did we build said 265?
  15. bfalfa55
    bfalfa55
    Not yet, I am the ultimate procrastinator ! I think about it too much and second and triple guess myself. I have just been enjoying my 55. I do plan on doing it this summer. It's actually been tough trying to find a machine shop that will even touch it believe it or not. Most seem afraid to touch it!
  16. Roothawg
    Roothawg
    Wow, its just a sbc, nothing too different.
  17. 427 sleeper
    427 sleeper
    If a machine shop won't do that, you're at the wrong shop.
    Sent from my SM-G892A using The H.A.M.B. mobile app
  18. bfalfa55
    bfalfa55
    I know Roothawg, I said the same thing it's just an sbc. 427 sleeper, that's why it isn't at any of those shops. I throw most of them for a loop when I talk about pulling the rear cam bearing to modify the oiling. Most have zero clue what I am talking about. I also find most want to do a complete rebuild and this doesn't need it. It's already been tanked, bored and balanced. Seems like they want to make their top dollar not just a little money for the things I want done.
