I usually run 2.5 PSI on my early 97 carbs but we just installed Speedways 9super7 carbs on a friends car. Do we need to go 2.5 or can they run more, say around 5/6 psi? Thanks.
WARNING: The carb will operate suitably with fuel pressures ranging from 1 ½ psi to 4 psi, with a desired setting of 2 ½ psi to 3 psi. Fuel pressure from 4 psi to 7 psi will cause the carburetor to run excessively rich and may cause flooding. Check fuel pressure at the fuel log or carb inlet when the engine is running (it may be necessary to fabricate a “T” fitting and temporary fuel line). Most aftermarket electric and high performance mechanical fuel pumps produce 6 to 9 psi fuel pressure and are not suitable for use with the 9 Super 7 carb without using a pressure reducing regulator (such as our p/n 560- 58500). Flooding or leaks caused by excessive fuel pressure do not indicate a faulty carburetor, and may not be covered under This is per speedways site.
