Technical 9 inch Ford rears
Discussion in 'Traditional Hot Rods' started by steamer, Mar 1, 2014.
  1. steamer
    steamer
    What years did the 9 inch come from? Trucks and cars? I need to find a drive-shaft?
  2. squirrel
    57-86ish in trucks, cars quit using them around 1979. There were several different yokes, and a few different U joint sizes.
    I"m sure that doesn't answer your question. But I don't know what your question is. Are you trying to figure out what to get a driveshaft out of, to fit some 9" rear that you have? If so, you'll want to measure the size of U joint it takes.
  3. jseery
    jseery
    from Wichita KS
    I have spent hours in salvage yards looking for good drive shafts and every time it ended up cheaper and easier to just have one made. So, you might consider looking for a shop that builds them. That way you have the length and yokes you want and they almost always need balanced anyway. One of the issues with salvage shafts is they tend to move car / trucks around with forklifts and the bend / damage the ones that are still in the cars. I don't know cars very well, but most years on F series trucks and vans have 9 inches in them from the 60s thru the 90s, but you have to check because they can be other than 9 inch.
  4. big duece
    big duece
    from kansas
    And it will be straight, and balanced too.
  5. 65COMET
    65COMET
    A lot depends on transmissions slip yoke and u-joint size,rear yoke length and the size of u-joint it takes,a lot of variables!!!! Makes sense to order a new driveshaft!!! JMO , ROY.
  6. saltflats
    saltflats
    from Missouri
    If its going in that 63 you will be better off going to your drive shaft shop.
  7. whtbaron
    whtbaron
    from manitoba
    x5... last one I had built was for a big truck and came in around $700... anything for a car should be much cheaper. Even with the big stuff every shaft we pulled had a slight bend in it. I just used the joints etc. from the junkers and had a truck shop build the new shaft. I broke 2 old ones, but (touch wood) the new one is going good for 2 yrs.
  8. if you find one you want DON't buy it. if its been standing in corner.If they are lieing down they don't take a set.Standing up they tend to bow if standing to long.Learned this the hard way. Many years ago i had 5 or 6 new ones built, for different hot rods.ITS the ONLY way to go.think i paid 150.00$ last one was ten years ago for sure. hth bob
  9. 40FordGuy
    40FordGuy
    Ditto, re; have a driveshaft made. Quick, easy, and worth the $$
    4TTRUK
  10. cheesegrater
    cheesegrater
    from california
    A good driveshaft shop can get you anything you need no need to junkyard shop at worst might need a crossover u-joint
  11. gimpyshotrods
    gimpyshotrods
    Physics does not work that way.:eek:
  12. squirrel
    It does, if someone stands all the bent driveshafts in a corner.
  13. gimpyshotrods
    gimpyshotrods
    You make a good point, Sir.
  14. Hurley50
    Hurley50
    from NC
    I had one made, it is much easier and safer.
  15. whtbaron
    whtbaron
    from manitoba
    ...or something got stacked against them. Not so sure I'd laugh this one off. I know a case where new cylinder sleeves for a diesel engine got stacked sideways for a couple years, and they were all junk. Went out of round. I wouldn't have believed it if I hadn't seen it personally either.
  16. big duece
    big duece
    from kansas
    I was always told to store crankshaft standing up, and to never leave them laying down.
  17. Mr48chev
    One thing on wrecking yard driveshafts that are out of the rig is you don't know what happened to them before they got pulled out of the rig. The yard here move the wrecks around with forklifts that damage as many driveshafts as they leave good.
  18. jseery
    jseery
    from Wichita KS
    All of the shafts I have had built were in the $150 to $200 range, but sure it depends on the location and the shop. As far as parts do, the cheapest source I have found is buying a truck or van with the parts you want on it. Remove them and haul the remains to a crusher. It always turns out way cheaper than buying from salvage, at least in my area. I figure a 9 inch rear axle is worth $150 to $200 and a drive shaft $50 to $100. If I pull the transmission (maybe another $100) and rims (say $10 to $15 each) I can pay $300 or $400 for a truck, strip it and still get $150 or so at the crusher. If it happens to have an engine core or other parts, so much the better. Anyway, works for me!
  19. Jalopy Joker
    Jalopy Joker
    for info about Ford 9", and what they were in search for: kevinstang.com
  20. gimpyshotrods
    gimpyshotrods
    Physics still does not work that way. Unless or until you apply enough stress and strain to fully surpass both the elastic range, and the plastic range, you will do nothing to permanently disturb the shape of the metal.
    All of the previously described scenarios have a different explanation than the one provided.
  21. whtbaron
    whtbaron
    from manitoba
    Buy yourself a set of cylinder sleeves and try it. I'm not aware of anything being stacked on top of them.
  22. gimpyshotrods
    gimpyshotrods
    You are entitled to you own opinion, buy not your own laws of physics. Those are non-negotiable.
    Being unaware is not conclusive exclusion. Existence is not contingent on acknowledgement.
  23. this thread is amazing! to the OP i have run whatever driveline that fits properly! they make combo u-joint to fit damm near anything. i have never been sent packing to find another driveline because they didn't make u-joint for the application.
