9" ford question
Discussion in 'The Hokey Ass Message Board' started by XWYNNSGUY, Dec 9, 2013.
  1. XWYNNSGUY
    XWYNNSGUY
    Hey all, I have a Ford 9" with 28 spline axles with small lug pattern in my project. I want to put 5.5 lug axles in it, I have lots of old ford wheels and the fronts are 5.5. Do I need Bronco or f100-150 axles? they are 26" and 30.5" long from the drum face, bearing OD 3.150 plate 3.5 x 2.5. Please point me in the right direction. Thx, Tom
    tlsaleeba@comcast.net
  2. go-twichy
    go-twichy
    have the ones you have drilled.
  3. R Pope
    R Pope
    Lots of 9" rears out there, find one that has the wheel bolt pattern you want. Too many different axle configurations to mix and match pieces.
  4. oldspwr
    oldspwr
    You can't have the axles drilled for a different bolt pattern since the have large holes (windows) in them... There is a guy on here who sell the jigs for redrilling different bolt patterns and he mentions it on his website also... just found him - rottonleonard
    http://www.jalopyjournal.com/forum/showthread.php?t=679673
  5. sunbeam
    sunbeam
    Broncos are 27 and 29
  6. This is probably more than you really wanted to know but this is what I found when working on the Bronco axle under my Deuce pickup. HRP
    EARLY BRONCO AXLE LENGTHS:
    FORD 9":
    DRUM TO DRUM LENGTH 58"
    AXLE FLANGE TO AXLE FLANGE...53"
    28 SPLINE AXLE
    SMALL BEARING DIM'S...2.835" O.D. / 1.376" I.D.
    LARGE BEARING DIM'S...3.150" O.D. / 1.531" I.D.
    1310 SPICER U-JOINT
    PRE 69 USES SMALL HUB CARRIER
    PINION DEPTH.....1.900"
    BACKLASH........ .008-.012"
    PINION PRELOAD.......13-15 in lbs
    CARRIER CAPS......60 ft lbs
    RING GEAR..........60 ft lbs
    66-75 (SMALL BRG) (28 SPLINE) 1 3/4" BRAKE R.H..29.62"
    66-75 (SMALL BRG) (28 SPLINE) 1 3/4" BRAKE L.H..27.25"
    66-75 (LARGE BRG) (28 SPLINE) 1 3/4" BRAKE R.H..29.31"
    66-75 (LARGE BRG) (28 SPLINE) 1 3/4" BRAKE L.H..26.94"
    74-75 (LARGE BRG) (28 SPLINE) 2 1/2" BRAKE R.H..29.75"
    74-75 (LARGE BRG) (28 SPLINE) 2 1/2" BRAKE L.H..27.25"
    76-77 (LARGE BRG) (28 SPLINE) 2 1/4" BRAKE R.H..29.68"
    76-77 (LARGE BRG) (28 SPLINE) 2 1/4" BRAKE L.H..27.25"
    DANA 44:
    30 SPLINE INNER / 19 SPLINE OUTER
    71-75 DRUM BRAKE
    76-77 DISC BRAKE
    71-77 INNER....5-260X U JOINT....L.H..18.31"
    71-77 INNER....5-260X U JOINT....R.H..27.94"
    NOMINAL PINION DEPTH....2.625"
    BACKLASH...........004-.009"
    PINION BEARING PRELOAD....20-40 in.lbs. new
    PINION NUT....200-220 ft lbs
    CARRIER CAPS....70-90 ft lbs
    RING GEAR.....45-65 ft lbs
    COVER.......30-40 ft lbs
    WHEEL BRG INNER.....50 ft lbs then back off 90 degrees
    WHEEL BRG OUTER.....80-100 ft lbs
    SPINDLE..........30-40 ft lbs
    _________________
  7. 19Fordy
    19Fordy
    28 spline 9 inch axle flanges have too small a diameterto re-drill to 5 x 5 1/2 bolt pattern.
