8BA in 35 Ford
Discussion in 'The Hokey Ass Message Board' started by 36el, Nov 26, 2011.
  1. 36el
    36el
    from sweden
    Does anybody know if a 8BA fits straight into a 35 or will the distributor hit the radiator.
  2. moefuzz
    moefuzz
  3. 32Gnu
    32Gnu
    I don't think the problem is going to be the distributor.. It may be the fan however...
    I put one in my deuce this year and i had to modify the fan assembly to make it all fit.., I had posted a response to a guy on here concerning it and what I did.. Pm me if I can help..
  4. 296 V8
    296 V8
    from Nor~Cal
    Mount the early generator w fan and you can see what needs doing.
    Machine a custom left water pump pulley that allows a second belt that runs the generator.
    A shorter belt then go’s in the stock location (crank to pumps) and requires a idler / tensioner.
    Note
    There are several different fans w deferring offsets and diameters …. needed to clear the distributor (its close)
    Also (like he said below)
    Rear sump truck pan required
  5. 2935ford
    2935ford
    Here's my '35 Slantback 8BA install. I had the truck block and pan. Only had to adjust the tie rod (stock axle) to clear the pan and I used an electric fan.
    T5, Red's Headers around the stock steering box (great fit).
  6. blucar
    blucar
    I have attached a pix of an 8BA engine conversion in my friends 36, as you can see the conversion is pretty simple if you use the truck/Merc style of water pumps and bellhousing.
  7. 36el
    36el
    from sweden
    Thanks A lot for your help
  8. Hot Rod Elvis
    Hot Rod Elvis
