Technical 8ba help
Discussion in 'Traditional Customs' started by Born-2-Late, Feb 25, 2016.
  1. Born-2-Late
    Born-2-Late
    Ok I'm a noob hoping I haven't done something seriously wrong. I my flathead was leaking water from left rear head I pulled it disassembled it hat the machine shop clean and check it the block had apparently shaved and wasn't level the old man said he would try to true it up and he did he said I would be OK if I didn't have shaved heads. I went threw 6 sets of heads before we had a set that wasn't cracked warped or shaved. (I have stock heads from a truck) bored it 60 over I then built the engine with everything new minus rods and I had a standard crank I turned 10/10 new everything else have a isky 88 full race cam manly valves with all guides retainers clips new have isky springs Rodgers adjustible lifters and reds headers currently running stock distributer with petronics installed and a offy intake with 600 edelbrock 4 barrel (changing both soon was just something I already had at the time) oil pump all gears and timing chain are new water pumps are new style etc hooked up the new aluminum radiator and cranked it in the floor to do the cam break in and make sure all was good she run like a dream. Installed in the car drove to get my smithy mufflers installed picked it up sounds great drove home when I got home all seemed well I asked me dad to take it up the road so I could hear it from a spectators point of view. He only drove a out a country block came back I heard a knocking he pulled in cut it off I said crank it back up it seemed to be gone I reved it up a little held it there and let off as it came to idle it was back it was a fairly slow fairly deep distinct knock reed it up and it went away dropped to idle was back cut off the car waited maybe 2 min cranked it and it wasn't there but about 15sec later it came back kinda quieter and spuratic at first them it got back into rythem yet still a little quieter dad says the noise sounds like a wrist pin sound but it's not consistent and they are all new have 40lbs oil pressure at idle and about 50 when I Rev it up a little sound seems to be coming front the center of the top of the engine I'm frustrated and lost its my first build I have spent 2 1/2yrs replacing all steering suspension fuel system Tranny parts etc etc will be extremely grateful for any advice
  2. Born-2-Late
    Born-2-Late
    By the way I build it not the machine shop
  3. Born-2-Late
    Born-2-Late
    Oh and it's my first flathead build not first engine build. Sorry for all the typos I'm using my cell phone and have fat fingers
  4. alchemy
    alchemy
    If I typed all that on a phone with my thumbs I wouldn't be able to pick up a drink for a week.
    Sorry, it gave me a headache just trying to read it. But, I gather you have a non-consistent knock that could be coming from anywhere. I suggest you use a long extension as a stethoscope (Place end against a spot on engine and other end in a cup made by your hands. Listen in your hands.) and try to find where the knock is coming from. Then report back to us.
    It could be wrist pins, or it could be a hundred other things. Maybe even in the trans/clutch area. Who knows.
    >>>>>>> Go up there and edit your first post with some periods, commas, and paragraph spaces. <<<<<<<
    Hnstray likes this.
  5. Born-2-Late
    Born-2-Late
    I am extremely busy during the week with my job and I have the car at my dad's but I picked up a actual mechanics stethoscope I plan to use it Saturday ty I have done the extension trick before actually haha
  6. Russco
    Russco
    from Central IL
    Did you check piston dome to head clearance? It could be the piston dome or domes slightly hitting on the head. Some of the aftermarket piston domes do not match up to the heads. Also you must check clearance over the entire dome of the piston BTW you could have just got shim gaskets to compensate for the decked block.
  7. Born-2-Late
    Born-2-Late
    Just trying to get any opinions possible so when I get to jump on it I'm not just going random
  8. Born-2-Late
    Born-2-Late
    Never can have to much info from ppl that have been there. The flathead is new for me tho I love them and have been buying them up as much as I could for a few years it's my first build
  9. Born-2-Late
    Born-2-Late
    Yes I did it hit when there was no gasket and cleared with a old compressed gasket so I got a good thick gasked
  10. Born-2-Late
    Born-2-Late
    My confusion is that it goes away when reved up but comes back at idle
  11. check crankshaft end play and flywheel bolts and clutch bolts being too long...........................
  12. alchemy
    alchemy
    Check plug electrodes being smashed flat Happened to me once Cured it with a different brand of plugs But could also maybe just use an extra washer from an old set of plugs Happened with a stock set of Canadian aluminum heads that had not been milled so it was very surprising.
  13. Born-2-Late
    Born-2-Late
    Have a Brand new centerforce clutch pressure plate and flywheel that is installed with the provided hardware.
  14. Born-2-Late
    Born-2-Late
    I figured I would pull plugs first after using stethoscope
  15. Born-2-Late
    Born-2-Late
    Will definitely look into the end play ty for that
  16. 97
    97
    New Timing chain? ????? I was going to ask if you had the correct 8BA timing gears... they thrust in the opposite direction to earlier motors . Using the wrong timing gears has been blamed in the past for failing lifters and camshafts. Rodgers lifters? Are they good quality , I have never heard of them ( but that dosen't mean a lot), but I do know there are some "soft" lifters out there which disintegrate after a few miles.
  17. Born-2-Late
    Born-2-Late
    Haha was at work so was distracted meant Johnson not Rodgers
  18. alchemy
    alchemy
    Geez, I missed that. If you added a timing chain that's got to be the source of the noise. Remove that and see if there are any unwanted sounds left. o_O
  19. Born-2-Late
    Born-2-Late
    Theres no chain the gears are new bought all parts from either shoebox central speedway or Dennis carpenter
  20. Born-2-Late
    Born-2-Late
    Ok quick update pulled plugs none was bent checked compression 5 cylinders was 80psi 2 was 70 psi 1 was 60 psi I have only put 60mi on it so far I know that I got to adjust lifters how many miles do yall recommend before I do that also didn't hear the loud noise but didn't have time to drive it more than a couple miles. I know my throw out bearing is making some noise but don't think that was the same thing hopefully I'm wrong will be really working on it this weekend
  21. Born-2-Late
    Born-2-Late
    Note I did one cylinder at a time left other plugs in and didn't touch carb was just checking for variations was in a crunch for time
  22. steinauge
    steinauge
    from 1960
    Make sure the throttle is wide open when doing compression test,otherwise you get a false reading. If the noise occurs at idle go along and short one plug at a time to ground.If the noise goes away when you ground a particular plug and comes back when you dont that is your problem cylinder.
  23. Born-2-Late
    Born-2-Late
    Will do ty for that!!! I am sure I need to readjust my lifters too
  24. Born-2-Late
    Born-2-Late
    I'm wondering if the centerforce clutch requires a different throw out bearing
  25. Born-2-Late
    Born-2-Late
    I have centerforce flywheel, clutch, and pressure plate but using a stock throw out bearing. It makes a little noise when I touch the peddle I assumed it was due to the output shafts isn't perfect it shows its age
  26. Born-2-Late
    Born-2-Late
    Maybe wrong will try to research that
  27. alchemy
    alchemy
    Check the clearance of the clutch fingers to the trans input snout when fully depressed. Also check that the stock bearing surface covers the fingers on their full travel.
  28. Born-2-Late
    Born-2-Late
    Still on the lift been hammered down all day adjusted clutch installed drop spindles and dropped shocks already had drop springs fixed a gas leak I found when I ran out of gas this morning haha
  29. Born-2-Late
    Born-2-Late
    Been trying to get the new steering components half ass adjusted to get it to the alignment shop
  30. gary terhaar
    gary terhaar
    from oakdale ny
    Exactly , egge is the worst I have found to date. Stock is a 7 in radi and egge is something like 4.5-5 in radi. I had made a cutter to shape the heads to a 5 in radi and cut the heads for a fix . Ross forged are spot on.
    People are more apt to use a lower cost cast piston if it was to be rebuilt again so the head was the more logical way instead of cutting the piston dome.
